BurnInTest v10.2 hang-up in COM port 1-6 test
  • zenolee
    • May 2024
    Hi.
    We saw BurnInTest V10.2 run COM port 1-6 115200 baudrate with 100% setting, run about in 20min-2hours hang up issue. Here is my configuration:
    Intel AmstonLake X7433RE
    Memory: DDR4 16G
    SSD:Sandisk SD6SN1M128G
    OS:Windows 11 23H2
    I had modify duty to 90% it's will run 12hours, did you had any recomment about duty rate. And our com port had transfer/receiving in windows 11 and without any error.
    • 11112
    Did the whole machine lock up or just BurnIntest?
    COM ports are super old and slow by today's standards. You should be able to run 6 of them at the same time at 100% (assuming nothing else is running at the same time).
    • zenolee
      • May 2024
      Hi.
      When hang up whole system freeze keyboard/mouse can't move, and then system will black out about 3 mins. Attached the debug log by "C:\Program Files\BurnInTest\bit.exe" -u option for your reference. Thanks.
      -> When run COM1-6 CPU using about 40% to 20%, we only run COM port test item. When it hang up sometime it will had buffer receive overrun error message.
        • 11112
        It (of course) isn't normal that the machine locks up.
        Very likely it is hardware failure or device driver bug.
        Can you run the same test on a different computer?
        • zenolee
          • May 2024
          We had try it on other computer is working about 15 hours, Almost same configuration but different CPU (x7835RE).
            • 11112
            So that would be further evidence that there is something wrong with your X7433RE machine.
            • zenolee
              • May 2024
              We had set baudrate from 115200 to 9600 duty 100%, it can run about 12hour without erro/freeze. Did you had recomment about it. How to set baudrate for testing COM port?
              Can you tell it's driver or hardware failure cause this issue?
                • 11112
                Based on the information provided our best guess is that it is a hardware fault or device driver bug.
                115,000bits/sec is super slow. Modern serial connections (e.g. USB) are doing 10,000,000,000bits/sec.
                Running your COM ports at their limit is not a reason for the machine to crash.
                We aren't going to be able to fix your hardware remotely. Sorry.
                • zenolee
                  • May 2024
                  Hi.
                  We had two SuperIO chip, If we select only single SIO COM port,​ it's will run about 15 hours without any error or freeze. Did you had any comment or saw similar case before? Thank you..
                    • 11112
                    We have never come across a system with two super I/O chips on a motherboard. Seems redundant.
                    A simpler chip like the AX99100 should be all that is required for additional serial ports.
