Burn in test FAIL 3D Graphics, No operations reported in timeout period
  • Stanley Shen
    • Apr 2023
    • 12
    Burn in test fail
    could you help us to find root cause?
    System Summary:
    Windows 11 Professional Edition build 26100 (64-bit)
    1 x Intel(R) Core(TM) Ultra 7 155H [1996.9 MHz]
    31.6GB RAM
    Intel(R) Arc(TM) Graphics, NVIDIA GeForce RTX 4050 Laptop GPU (Mobile)
    477GB SSD
    General:
    System Name: DESKTOP-EFCNRCJ
    Motherboard Manufacturer: Standard
    Motherboard Name: Standard
    Motherboard Version: Standard
    Motherboard Serial Number: Standard
    BIOS Manufacturer: American Megatrends International, LLC.
    BIOS Version: B.0.05B00
    BIOS Release Date: 06/14/2024
    BIOS Serial Number: Standard
    TPM: Available, V2.0
    CPU:
    CPU Type: Intel(R) Core(TM) Ultra 7 155H
    CPUID: Family 6, Model AA, Stepping 4
    Physical CPU's: 1
    Cores per CPU: 16
    Threads per CPU: 22
    P-Cores: 6
    P-Threads: 6
    E-Cores: 10
    E-Threads: 20
    Hyperthreading: Enabled
    CPU features: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 DEP PAE Intel64 VMX SMX Turbo AES AVX AVX2 FMA3
    Clock frequencies:
    - Measured CPU speed: 1996.9 MHz [Turbo: 4493.0MHz]
    - Multiplier: x20.0 [Turbo: x45.0]
    - Base Clock: 100.0 MHz
    - Multiplier range: Min: x4, Max non turbo: x30 [Ratio: 8C: x46, 7C: x46, 6C: x46, 5C: x46 4C: x48, 3C: x48, 2C: x48, 1C: x48]
    Cache per CPU package:
    - L1 Instruction Cache: 6 x 64 KB
    - L1 data cache: 6 x 48 KB
    - L2 cache: 9 x 2 MB
    - L3 cache: 24 MB
    Memory:
    Total Physical Memory: 32320MB
    Available Physical Memory: 28262MB
    Memory devices:
    Slot 1:
    - 16GB DDR5 SDRAM PC5-44800
    - Samsung M425R2GA3PB0-CWMOD, serial#: 0x51DA2B3, wk/yr: 36/2023
    - 1.1V, Clk: 2800.0MHz, Timings 45-45-45-90 (@ Max. freq.)
    Slot 2:
    - Samsung M425R2GA3PB0-CWMOD, serial#: 0x4D9D25F, wk/yr: 26/2023
    Virtual memory: C:\pagefile.sys (allocated base size 32768MB)
    Memory SPD:
    DIMM#0
    Memory type: DDR5 SDRAM
    SPD revision: 1.0
    Manufacturer: Samsung
    Manufacturing date: Year: 2023, Week: 36
    Serial number: 051DA2B3
    Part number: M425R2GA3PB0-CWMOD
    Clock speed: 2800.0 MHz
    Memory size: 16384 MB
    ECC: No
    Module voltage: 1.1V
    DIMM#1
    SPD revision: 1.0
    Manufacturing date: Year: 2023, Week: 26
    Serial number: 04D9D25F
    ECC: No
    Graphics:
    Memory: 128MB
    Driver provider: Intel Corporation
    Driver version: 31.0.101.5522
    Driver date: 5-12-2024
    Chip Type: 0x28A1
    DAC Type: Integrated RAMDAC
    Memory: 6140MB
    BIOS: 95.07.40.40.c1
    Driver provider: NVIDIA
    Driver version: 556.07
    Driver date: 6-13-2024
    Monitor 1: 2560x1440x32 165Hz 144 DPI (Primary monitor)​
    CPU looks to be running very hot. Up to 103C in some cases. I can't imagine this is normal.
    3D failure is likely a hardware failure or device driver crash under high load. Which then results in a timeout.
    You might want to check the Windows event log around the time of the error (just before 2024-06-17 13:53:22). Driver crashes sometimes get logged.
    You could also run BurnInTest in debug mode to collect more detailed logs. No need to run a 48h test for this. Just run it until the error occurs.
