BurnInTest Linux V5.0 (1015) USB 3.0 Loopback Test AutoStopCycles Not Working
  • ParkerW
    • Dec 2024
    I am running BurnInTest Linux V5.0 (1015) in command line, and my goal is to have the test run 5 cycles of the USB test on the one loopback plug. The following are some of the key settings used in cmdline_config.txt, the full config is attached:
    <DutyCycles>
    AutoStopMinutes 0
    AutoStopCycles 5
    USB 100
    </DutyCycles>
    <USB>
    AutoSelectAllUSB
    RunUSBBenchmark
    USB3Connection Auto
    </USB>
    It starts the test as expected, running operations on the single USB 3.0 loopback plugged in, but when it reaches 5 cycles, it continues. I let it go for 9 cycles before stopping it. Then, the AutoStopMinutes was changed to 20 and the test was rerun. The test completed 6 cycles and stopped at 20 minutes.
    I see another forum post was made in March where a different user had the same issue. A comment was made that a fix would be in the next public release, which in the patch notes appears to be Version 5.0 build 1010 "Fixed issue where USB & network tests did not stop when using cycle count to stop test run." Wondering if the same bug has come back? Or is there another setting in the config I should be looking at?
    Thank you,
    Parker
    • 335
    Can you try running the latest build we just released which should fix this:
    https://www.passmark.com/products/burnintest/bitlinux_download.php
    • ParkerW
      • Dec 2024
      Hi Simon,
      I ran a quick test on build 1016, setting it for 0 minutes and 1 cycle. The test correctly did 1 cycle, so it appears the fix worked.
      Thanks!
      Parker
