Burn In Mode
  • zenmota
    • Sep 2014
    • 215
    #16
    Thanks, I guess I missed in the help file.
    Still not sure if this is normal:
    Any info on the Enable Testing With Constant Work Per Unit Time in the Battery Test where if I uncheck both, run Battery Test then go back and look at it, both will be checked (even though I unchecked both). If I only check CPU run test go back look at it, both or checked again. If only check Disk, run test and go back and look at it, only Disk is checked. By checking I mean the Disk and CPU options.
      • 332
      #17
      We are able to reproduce the issue, will be fixed for the next build
      • zenmota
        • Sep 2014
        • 215
        #18
        Ok, thanks for looking into it and all the info on the Battery Test.
