Can SD cards be tested with less intensity than hard disks?
  • shadow
    • Nov 2009
    • 11
    Dear Passmark,
    My system-under-test has both spinning hard disks and SD cards. These get lumped in BIT into one category called "Disk." I want to know if I can make the SD card tests less intense than the hard disk tests. This would better reflect real-world usage. The duty cycle adjustment for Disks seems to apply equally to hard disks and SD cards.
    I did research Seek Count and Duty Cycle Override, but those variables don't seem to be what I'm looking for. Please let me know if I can adjust test intensity between SD cards and hard disks separately. Thanks.
    -shadow
    The "Duty Cycle Override" setting is what you are looking for.
    100% is max load.
    1% would be very low load.
    Some SD cards get absolutely hammered in the real world. Security cameras (recording 24x7) and dash mounted cameras are good examples.
