setting usb
  • James Hoopes
    • Mar 2007
    • 15
    setting usb
    When I click on the tab for USB the program exits and I have to start it again
    What version of BurnInTest are you using and what O/S?
    • James Hoopes
      • Mar 2007
      • 15
      version 5.2
      • James Hoopes
        • Mar 2007
        • 15
        I am using version 5.2 (32bit)
        • CJ
          • May 2006
          • 21
          We need more info my friend
          What OS? XP / Vista / Win2000 ?
          Does it happen on other machines ?
          Have you checked and updated the USB drivers?
          Have you updated the Mainboard northbridge drivers?
          Have you tried updating the BIOS?
          Have you tried reinstalling BurnIn test?
          Do you have the USB passmark loopback device plugged in?
            There is a known issue with DEP settings in some O/S's. But otherwise the problem is not known, so more details are required to investigate.
