Video Play fail - Old Celeron 850 Mhz system freeze
  • Mimi1er
    • Apr 2007
    My mother's computer freeze since a lot of time... I try to correct this problem...
    I remove allways PCI card (sound, TV tunner, network....) and the problem is allways...
    I change the RAM (64x2 + 256 Mo PC133 => a new 256 Mo PC133) and the problem is allways...
    I change the video card (GeForce 4 => Geforce FX 5200) and the problem is allways...
    I format and reinstall OS (Windows XP Home) and the problem is allways...
    When I try BurninTest, all tests are successfull except 'Video Play'.
    I can run all the test (without Video Play) in the same time and all was OK, but when I run Video Play only or with another test, the PC freeze.
    I can't do nothing ! The mouse and the keyboard are disabled !!!!
    This problem appear without Burnin Test sometimes, when I run a website or when i don't anything. Sometime, I must boot 5 or 6 time the computer to arrive under XP...
    The computer's configuration :
    MSI 815 EP Pro, Intel Celeron 850 Mhz
    256 Mo PC133
    Windows XP
    Nvidia Geforce Fx 5200
    Directx9
    Anybody have the solution ???? I don't know !!!!!!
    Help me please!!!!
    Thanks a lot
    If you can't boot the machine reliably and you have swapped a few of the main componets, then it isn't looking good. Given tha age of the machine, I would dump it rather investing even more time in it.
    I assume that once upon a time the machine was working well. So it probably isn't a BIOS fault. You don't have much left to swap out. Only the power supply, CPU and motherboard are left and a system freeze might be caused by any of them being faulty.
    • Mimi1er
      • Apr 2007
      Thanks for your reply.
      I will try to change power supply and after... trash if the problem is allways
      (sorry for my bad level in English....)
