RawReadErr very high, spinup 0 ms
  • Newbie
    • Oct 2007
    I've downloaded and installed Diskcheckup v2.1, and, I found the following report fm Diskcheckup.
    There is a TEC date with a very high raw read error. But I am confused with the spin up time 0 ms parameter. This is a fairly new drive about a month old. May I request your help in this regard, please.
    DiskCheckup Version: DiskCheckup V2.1 Build: 1000
    SmartDisk DLL Version: SmartDisk DLL SDK v1.0 Build: 1013
    Time of export: 17:42:00 15-Oct-2007
    Device ID: 0
    Device Capacity: 76319 MB
    Serial Number: 9QZ3T2K9
    Model Number: ST380215A
    Firmware Revision: 3.AAD
    Partitions:
    C: 20000 MB
    D: 25000 MB
    E: 25165 MB
    IDE Registers:
    Features: 0x0
    Sector Count: 0x1
    Sector Number: 0x1
    Cylinder Low: 0x0
    Cylinder High: 0x0
    Drive Head: 0xA0
    Command: 0xEC
    ID Sector:
    Cylinders: 16383
    Heads: 16
    Sectors per track: 63
    Cur Cyls: 16383
    Cur Heads: 16
    Cur Sectors/Track: 63
    Bytes per track: N.A.
    Sectors per track: N.A.
    Gen Config: 3162
    Buffer Type: 0
    Buffer Size: 4096
    Vendor Unique: 0 0 0
    More Vendor Unique: 0x8010
    ECC Size: 4
    Double Word IO: 0
    Capabilities: 12032
    PIO Timing: 512
    DMA Timing: 512
    BS: 7
    Current Sector Capacity: 16514064
    Total Addressable Sectors: 156301488
    Mult. Sector Stuff: 272
    Single Word DMA: 0
    Multi Word DMA: 7
    SMART ATTRIBUTES:
    ID Description Raw Value Status Value Worst Threshold TEC
    1 Raw Read Error Rate 99557651 OK 115 100 6 31 Mar 2008 23:19:19
    3 Spin Up Time 0ms OK 97 97 0 N.A.
    4 Start/Stop Count 69 OK 100 100 20 N.A.
    5 Reallocated Sector Count 0 OK 100 100 36 N.A.
    7 Seek Error Rate 2933377 OK 64 60 30 N.A.
    9 Power On Time 73 OK 100 100 0 N.A.
    A Spin Retry Count 0 OK 100 100 97 N.A.
    C Power Cycle Count 69 OK 100 100 20 N.A.
    BB (Unknown attribute) 0 OK 100 100 0 N.A.
    BD (Unknown attribute) 0 OK 100 100 0 N.A.
    BE Temperature Difference from 100 706805801 OK 59 54 45 N.A.
    C2 Temperature 41 C OK 41 46 0 N.A.
    C3 Hardware ECC Recovered 170067301 OK 90 67 0 N.A.
    C5 Current Pending Sector Count 0 OK 100 100 0 N.A.
    C6 Uncorrectable Sector Count 0 OK 100 100 0 N.A.
    C7 UltraDMA CRC Error Count 0 OK 200 200 0 N.A.
    C8 Write Error Count 0 OK 100 253 0 N.A.
    CA Direct Address Mark Error Rate 0 OK 100 253 0 N.A.
    Not all drives report all values. So 0 can be normal for some drives.
    The TEC date is just an rough estimate, not an accurate prediction.
    • Newbie
      • Oct 2007
      Do I ask for a replacement?
      Thank you very much for your swift response. I would be grateful if you could clarify whether I need to ask for a replacement for this drive? Thanks in advance.
        There were no failures reported. So I think the drive is OK (at the moment).
        • Newbie
          • Oct 2007
          Thank you very much, I'm really relieved.
