Read Error rate.
  • John
    • Jul 2008
    Read Error rate.
    I have just downloaded the new Diskcheckup V2, and have run the checks, and noticed i am getting a read error rate!
    What does it mean. I understand that it has a threshold rate etc, but the computer does not appear to be suffering any ill effects Yet!
    What is the suggested action, and how serious is it? I have attached a copy of the tests, so if someone out there can advise em as to what it all means in laymans terms i would be grateful.
    DiskCheckup Version: DiskCheckup V2.1 Build: 1001
    SmartDisk DLL Version: SmartDisk DLL SDK v1.0 Build: 1013
    Time of export: 20:34:00 21-Jul-2008
    Device ID: 0
    Device Capacity: 343397 MB
    Serial Number: 5NF0TDEK
    Model Number: ST3360832AS
    Firmware Revision: 3.04
    Partitions:
    C: 339224 MB
    IDE Registers:
    Features: 0x0
    Sector Count: 0x1
    Sector Number: 0x1
    Cylinder Low: 0x0
    Cylinder High: 0x0
    Drive Head: 0xA0
    Command: 0xEC
    ID Sector:
    Cylinders: 16383
    Heads: 16
    Sectors per track: 63
    Cur Cyls: 16383
    Cur Heads: 16
    Cur Sectors/Track: 63
    Bytes per track: N.A.
    Sectors per track: N.A.
    Gen Config: 3162
    Buffer Type: 0
    Buffer Size: 16384
    Vendor Unique: 0 0 0
    More Vendor Unique: 0x8010
    ECC Size: 4
    Double Word IO: 0
    Capabilities: 12032
    PIO Timing: 512
    DMA Timing: 512
    BS: 7
    Current Sector Capacity: 16514064
    Total Addressable Sectors: 268435455
    Mult. Sector Stuff: 272
    Single Word DMA: 0
    Multi Word DMA: 7
    SMART ATTRIBUTES:
    ID Description Raw Value Status Value Worst Threshold TEC
    1 Raw Read Error Rate 71396547 OK 49 46 6 01 Sep 2008 19:31:49
    3 Spin Up Time 0ms OK 97 97 0 N.A.
    4 Start/Stop Count 985 OK 100 100 20 N.A.
    5 Reallocated Sector Count 0 OK 100 100 36 N.A.
    7 Seek Error Rate 122845597 OK 81 60 30 N.A.
    9 Power On Time 2169 OK 98 98 0 N.A.
    A Spin Retry Count 0 OK 100 100 97 N.A.
    C Power Cycle Count 1002 OK 100 100 20 N.A.
    C2 Temperature 40 C OK 40 48 0 N.A.
    C3 Hardware ECC Recovered 71396547 OK 49 46 0 N.A.
    C5 Current Pending Sector Count 0 OK 100 100 0 N.A.
    C6 Uncorrectable Sector Count 0 OK 100 100 0 N.A.
    C7 UltraDMA CRC Error Count 0 OK 200 200 0 N.A.
    C8 Write Error Count 0 OK 100 253 0 N.A.
    CA Direct Address Mark Error Rate 0 OK 100 253 0 N.A.
    SMART HISTORY:
    Attribute ID: 1 Attribute Name: Raw Read Error Rate
    Date Value Worst
    Sat Jul 19 21:40:27 2008 51 46
    Sat Jul 19 21:41:05 2008 51 46
    Sat Jul 19 21:51:12 2008 51 46
    Mon Jul 21 20:23:07 2008 50 46
    Mon Jul 21 20:30:19 2008 49 46
    Mon Jul 21 20:33:24 2008 49 46
    Regards
    There are no failed values. So nothing to worry about. For the extrapolated TEC date, you haven't taken enough samples over a long enough period for the number to be even half accurate.
    • John
      • Jul 2008
      Raw read error rate
      Many thanks for the reply,
      I am very impressed with the prompt reply. Your response is far quicker than a service i currently pay for.
      Keep up the good work
      Cheers
