DVD/CD surface checking program
  • discrepair
    • Feb 2009
    Hi.
    Does anyone know where I can locate software to check media discs to see if they will operate correctly after the scratches have been removed from the surface.
    Cheers Ron
    • 11118
    If this is a DVD data disc (without any tricky copy protection schemes on the disc) then you can use BurnInTest to read the files.
    But you could just copy the contents of the disc to your hard drive as a quick test as well.
    • discrepair
      • Feb 2009
      Cheers for your reply
      But all the dvds are from video shops that I repair, so i need a very quick test.
        • 11118
        DVD movies are tricker to test (compared to data DVDs). DVD movies are designed to prevent you just copying the files.
        Ripping the whole DVD is the only way to be sure it is OK.
