Passmark DiskCheckup, explaining results help
  • rowfar
    • Jul 2010
    Hey Again made a new thread cuz of the large amount of text needed to be copied. I ran a new Disk test using your software Passmark DiskCheckup and I would like some help explaining the results of the test to me, I am not that good with hardware issues. I don't need everything explained, but I would like to know whether my computer issues (BSOD, ScreenFreeze's when playing MW2) could be caused by my harddisk. Atleast the hardware is good enough so it's harddisk or memory. Can't be software since I just did a new install of Windows 7 x64.
    [IMG]file:///C:/Users/Lintsen/AppData/Local/Temp/moz-screenshot.png[/IMG]Results:
    *** DiskCheckup V3.0 Build: 1000 Report ***
    SmartDisk DLL Version: SysInfo v1.0 Build: 1001
    Time of export: 14:58:10 13-jul-2010
    Device information:
    Device ID: 0
    Interface: ATA
    Device Capacity: 238473 MB
    Serial Number: S09QJ1ML606997
    Model Number: SAMSUNG SP2504C
    Firmware Revision: VT100-41
    Partitions:
    C: 131067 MB
    D: 107406 MB
    ATA information:
    Disk geometry:
    Cylinders: 98308
    Tracks/Cylinder: 138
    Sectors/Track: 36
    Bytes/Sector: 512
    Total disk sectors: 488397168
    Logical sector size: 512
    Physical sector size: 512
    Media rotation rate: N/A
    Buffer size: 8192 KB
    ECC size: 4 Bytes
    Standards compliance:
    ATA8-ACS Supported: No
    ATA/ATAPI-7 Supported: Yes
    ATA/ATAPI-6 Supported: Yes
    ATA/ATAPI-5 Supported: Yes
    ATA/ATAPI-4 Supported: Yes
    World Wide ID: 50000F001B606997
    Feature support:
    SMART supported: Yes
    SMART enabled: Yes
    SMART self-test supported: Yes
    SMART error log supported: Yes
    LBA supported: Yes
    IORDY supported: Yes
    CFast supported: No
    DMA supported: Yes
    Maximum Multiword DMA mode supported: 2
    Multiword DMA selected: None
    Maximum UltraDMA mode supported: 6
    UltraDMA selected: 5
    Maximum PIO mode supported: 4
    SATA Compliance: Yes
    NCQ priority information supported: No
    Unload while NCQ commands are outstanding supported: No
    Phy Event Counters supported: Yes
    Receipt of power management requests supported: Yes
    NCQ feature set supported: Yes
    SATA Gen2 Signaling Speed (3.0Gb/s) supported: Yes
    SATA Gen1 Signaling Speed (1.5Gb/s) supported: Yes
    Software Settings Preservation: Supported, Enabled
    In-order data delivery: Not supported
    Initiating power management: Supported, Disabled
    DMA Setup auto-activation: Supported, Disabled
    Non-zero buffer offsets: Not supported
    Trusted Computing supported: No
    Host Protected Area (HPA) supported: Yes
    Read look-ahead supported: Yes
    Read look-ahead enabled: Yes
    Write cache supported: Yes
    Write cache enabled: Yes
    Power management supported: Yes
    Security mode supported: Yes
    Security mode enabled: No
    Device Configuration Overlay (DCO) supported: Yes
    48bit Addressing supported: Yes
    Auto Acoustic Managment (AAM) supported: Yes
    Auto Acoustic Managment (AAM) enabled: No
    Power-up in Standby (PUIS) supported: No
    Advanced Power Management (APM) supported: No
    CompactFlash Association (CFA) supported: No
    General Purpose Logging (GPL) supported: Yes
    Streaming supported: No
    Media card pass through supported: No
    Extended power conditions supported: No
    Extended status reporting supported: No
    Write-read-verify supported: No
    Free-fall control supported: No
    TRIM command supported: No
    SCT command transport supported: Yes
    NV Cache enabled: No
    SMART ATTRIBUTES:
    ID Description Raw Value Status Value Worst
    1 Raw Read Error Rate 0x000000000000 OK 100 100
    3 Spin Up Time 0x0000000017C0 OK 100 100
    4 Start/Stop Count 0x000000001764 OK 95 95
    5 Reallocated Sector Count 0x000000000000 OK 253 253
    7 Seek Error Rate 0x000000000000 OK 253 253
    8 Seek Time Performance 0x000000000000 OK 253 253
    9 Power On Time 0x000000002A8A OK 100 100
    10 Spin Retry Count 0x000000000000 OK 253 253
    11 Calibration Retry Count 0x000000000000 OK 253 253
    12 Power Cycle Count 0x000000000C64 OK 97 97
    187 Reported Uncorrectable Errors 0x000000321549 OK 1 1
    190 Temperature Difference from 100 0x00000000001F OK 145 115
    194 Temperature 31 C OK 145 115
    195 Hardware ECC Recovered 0x0000003649EC OK 100 100
    196 Reallocation Event Count 0x000000000000 OK 253 253
    197 Current Pending Sector Count 0x000000000000 OK 253 100
    198 Uncorrectable Sector Count 0x000000000000 OK 253 253
    199 UltraDMA CRC Error Count 0x000000000000 OK 200 200
    200 Write Error Count 0x000000000000 OK 100 100
    201 Off Track Errors 0x000000000000 OK 253 100
    202 Data Address Mark Errors 0x000000000000 OK 253 253
    Tried my best to make them fix up but kinda messy
  • rowfar
    • Jul 2010
    S.M.A.R.T non messed up.
    SMART ATTRIBUTES:
      The disk is reporting that all its attributes are OK. So it should make you less suspect of a low level disk issue.
      If you are getting a BSOD then you should collect the details from the blue screen (or several of them if you see them often). There are often interesting details on the blue screen.
