Looking for suggestions
  • Equilibrium
    • Oct 2012
    Putting together a new computer, and trying to stay around $1500 max, give or take.... Looking for any feedback or suggestions anyone may have on what to tweak. I don't need a lot of space, seeing i don't run a lot of stuff, but what i do run i want to run well. Mostly looking to put together a solid gaming rig in the end. If you see anything i overlooked, like compatibility, please let me know. Here's what i think will be the end result.
    NZXT H2 H2-001-BK Black Steel / Plastic Classic Silent ATX Mid Tower Chassis
    Western Digital WD VelociRaptor WD2500HHTZ 250GB 10000 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    OCZ Vertex 4 VTX4-25SAT3-128G 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
    EVGA 02G-P4-2683-KR GeForce GTX 680 Superclocked, Signature 2GB 256-bit GDDR5 PCI
    Express 3.0 x16 HDCP Ready SLI Support Video Card
    CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE
    Certified Active PFC High Performance Power Supply
    CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9
    GIGABYTE GA-Z77M-D3H-MVP LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
    Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770K
    LG Black 14X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 12X BD-ROM 4MB Cache SATA BDXL
    Blu-ray Burner,3D Play Back (WH14NS40) - OEM
    Microsoft Windows 7 Home Premium SP1 64-bit - OEM
    All feedback welcome....
    I would be tempted to drop the VelociRaptor and put the money saved into a larger SSD.
    The cost of going to 16GB from 8GB probably isn't much. But on the other hand it isn't going to improve the performance much either.
    Might also be tempted to get a case with two USB3 ports on the front, depending on how hard rear access is going to be & what USB devices you have.
    Don't forget a monitor & maybe better heat sink if you are going to overclock.
