Are my components Ok?
  • GaXve
    • Mar 2020
    I recently purchased some new parts for a new system, while keeping some old parts from my old system (2014). I thought my system would be ok, but there seems to still be some lagging / choppiness and I'm wondering why? I know my motherboard isn't the top of the line, but I don't think it would be the cause of it. My old graphics cards perhaps?
    Parts in the system:
    ***** New *****
    - CPU
    AMD RYZEN 5 3600 6-Core 3.6 GHz
    - Motherboard
    ASRock B450M Steel Legend
    - RAM
    CORSAIR Vengeance RGB Pro 16GB (2 x 8GB) CMW16GX4M2C3200C16
    ***** Old (from 2014) *****
    - GPU
    2x Radeon Hd 7750 Eye6 2gb Ddr5 Pcie 6x Mini Displayport 70w Draw
    - Power Supply
    Cooler Master Extreme 2 Power Plus 625W ATX 12V Power Supply 20/24PIN 120mm Fan
    • 11112
    Using a SSD makes the world of difference if you are on an old HDD.
    Also dual GPUs often cause more problems than they are worth.
    • GaXve
      • Mar 2020
      Thanks for the feedback. In my old system, it wasn't a problem... I don't know. Maybe design architecture has changed... conversion of data...
      Oh, and I do have SSD hard drives
      • john44
        • Jul 2020
        If there aren't any driver issues, I would consider checking that BIOS is up to date, perhaps start with defaults, just one RAM module and 1 GPU (then switch GPUs), do some testing and then add one part at a time while you go from there in a process of elimination.
        Good luck.
