Hi everyone,
Just wondering if it is possible to set up a periodic max heat test.
Let's say I want to run the CPU at max heat for 20 mins, then idle for 20 mins, then back to max heat for 20 mins and on and on.... For a finite or infinite amount of time/cycles.
I need to log the temperature at all time.
Can I achieve this with a BurnInTest script?
And when I run the CPU at 100, it is on max load, and at 1, it is pretty much on idle. Am I right?
Any help is appreciated.
