Ram qty scores more than ram speed?
  • Pedro_The_Swift
    • Dec 2020
    • 7
    Is there a formula for this? Its doubtful anyone needs more than 16gb but if you can afford 132gb your score is better?
    I assume you are referring to PerformanceTest
    Formula's are here.
    https://forums.passmark.com/performa...-and-disk-mark
    Many business users need more than 16GB. Not so many home users however.
    4K video editing, database servers, running VMs, etc..
    Having a large disk cache also helps overall system performance.
    • Pedro_The_Swift
      • Dec 2020
      • 7
      Thank You!
      • Pedro_The_Swift
        • Dec 2020
        • 7
        I have two sets of ram, a twin stick 4600 and a 4 stick 2400, from my benching it seems the quad is better?
          Might depend on the CPU and the timings. Some CPUs had quad channel memory (so 4 sticks are better). And some high (clock) speed RAM sometimes have slow timings. Also some CPUs won't be able to run RAM at 4600 speeds. They might only go to 3000. Meaning the clock speed difference is smaller than you might be thinking.
