Passmark Hardware calibration.
  • Thandapani
    • Aug 2021
    Hi we need to know the calibration details of Hardware devices provided by passmark and the lifecycle(How many cycles it can be used) of the devices.
    These are the following hardware devices we are using, for these devices we need to know the calibration and lifecycle details.
    • USB 3.0 Loopback Plug + cable.
    • Serial Loopback Plug.
    • USB Short Circuit Tester.
    • Audio Loopback cable.
    • Passmark Software Bootable UFD.
      No calibration possible.
      No calibration possible (it is after all just a copper wire).
      No calibration possible (again, it is just a cable, not a measurement device).
      No calibration possible. This is a flash drive with software. You can't calibrate a flash drive.
    How many cycles they can be used depends on how roughly you treat them. All connectors will eventually wear out after 1000 of insertions.
