USB 3.0 Loopback plugs power issue
  • jungin
    • Jan 2022
    Hi All.
    I have question about USB 3.0 Loopback Plugs. I bought PM065 at 15/12/2021.
    At first test was successful and I didn't have problem while testing.
    I tried to another test at 29/12/2021 but the product didn't got power. (All led lamps are off and nothing on display)
    Can I get solutions to solve this issue?
    Thanks.
    • 969
    Possible things to try:
    • Try it with a different cable.
    • Try it on a different PC, preferably one with a different host controller.
    • Try just the one suspected faulty plug by itself without any other USB device connected.
    Does Windows OS recognize the plug when it is inserted into the machine? (USB Connect/Disconnect sound, or new entry in the Device Manager)
    Do you have the drivers installed on the system?
    If it is recognized by OS, there is the firmware updater here if you think it might be firmware related,
    https://www.passmark.com/products/us...k/download.php
    Can you provide more details of your testing and use of the USB 3.0 Loopback Plug?
    See this page for details about common failure modes for USB3.0 loopback plugs, plus possible solutions.
    • jungin
      • Jan 2022
      Hi Richard.
      After firmware update, device worked well.
      Thank you for your help.
