Drive not recognized
  • Eagletech
    • Jun 2015
    • 8
    I have a brand new Western Digital hard drive and Diskcheckup doesn't read any smart attributes and where the drive name would normally display in the upper box it just shows "Disk 0" with a red box with a minus symbol in it. It doesn't read the disk manufacturer's ID name or number. What does this mean?
    How is this drive connected to the motherboard? (USB, SATA, SCSI, etc...)?
    What is the model number of the drive?
    • Eagletech
      • Jun 2015
      • 8
      The drive is connected via a SATA cable to the motherboard internally. My original question related to a brand new hard drive I placed in a computer and sold to a client, so I don't any longer have access to that model number, but I have another computer in front of me that has the same issue and it is a Western Digital WD5000AAKS.
        Some motherboard have a mix of normal SATA ports and RAID controller SATA ports.
        What port are you using and what is the motherboard model?
        Can you run DiskCheckup in debug mode and send us the log,
        To do this you need to use the '-d' command line argument
        (Debug mode is off by default).
        • Eagletech
          • Jun 2015
          • 8
          From within the BIOS I just ran a Short Self-Test and it passed just fine.
          GSmartControl describes the minus box as: send command failed. I'm not sure what that means or how to resolve it.
          • Eagletech
            • Jun 2015
            • 8
            It is using a SATA port, not a RAID
            The Motherboard is: MCP61PM - HM Rev. 1.0A
            • Eagletech
              • Jun 2015
              • 8
              In Device Manager it says the drive is a SCSI Disk Device.
              • Eagletech
                • Jun 2015
                • 8
                Here is the debug log:
                0.140s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - DeviceIoControl(IOCTL_SCSI_GET_ADDRESS) failed with: 50, The request is not supported.
                0.140s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - DFP_GET_VERSION failed.
                0.140s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd
                0.140s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd (2)
                0.140s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd_cypress
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd_cypress (2)
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd_jmicron
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd_jmicron (2)
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd_sunplus
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd_sunplus (2)
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - ATA_IDENTIFY_DEVICE failed.
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 27:
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Number of extent: 1
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Creating thread GetSMARTInfoThread...
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Opening physical device #2
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Opened.
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - DeviceIoControl(IOCTL_DISK_GET_DRIVE_GEOMETRY) failed with: 21, The device is not ready.
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - DeviceIoControl(IOCTL_STORAGE_QUERY_PROPERTY) succeeded:
                Vendor: "Generic "
                Product: "USB CF Reader "
                Revision: "1.01"
                Removable: Yes
                BusType: 0x07
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - DeviceIoControl(IOCTL_SCSI_GET_ADDRESS) failed with: 50, The request is not supported.
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - DFP_GET_VERSION failed.
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd (2)
                0.156s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd_cypress
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd_sunplus (2)
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - ATA_IDENTIFY_DEVICE failed.
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 28:
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Number of extent: 1
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Creating thread GetSMARTInfoThread...
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Opening physical device #3
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Opened.
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - DeviceIoControl(IOCTL_DISK_GET_DRIVE_GEOMETRY) failed with: 21, The device is not ready.
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - DeviceIoControl(IOCTL_STORAGE_QUERY_PROPERTY) succeeded:
                Vendor: "Generic "
                Product: "USB MS Reader "
                Revision: "1.03"
                Removable: Yes
                BusType: 0x07
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - DeviceIoControl(IOCTL_SCSI_GET_ADDRESS) failed with: 50, The request is not supported.
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - DFP_GET_VERSION failed.
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd (2)
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd_cypress
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd_cypress (2)
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd_jmicron
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd_jmicron (2)
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd_sunplus
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 29:
                0.171s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Opening physical device #4
                Vendor: "Generic "
                Product: "USB SD Reader "
                Revision: "1.00"
                Removable: Yes
                BusType: 0x07
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd (2)
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd_cypress
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd_cypress (2)
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd_jmicron
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd_jmicron (2)
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Enter DoScsiPassthroughCmd_sunplus
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Exit DoScsiPassthroughCmd_sunplus (2)
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - ATA_IDENTIFY_DEVICE failed.
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 30:
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 31:
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 32:
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 33:
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 34:
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 35:
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 36:
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 37:
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 38:
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 39:
                0.187s - SysInfo: SysInfoDll: 00:30:01 05-Jun-2015 - Drive 40:
                • Eagletech
                  • Jun 2015
                  • 8
                  I'm on the West Coast of the US so I'm going to head to bed now. I will check back on your replies in the morning.
                  I really appreciate all your help!!!
                  • Eagletech
                    • Jun 2015
                    • 8
                    David, I'd really appreciate your perspective on this issue.
                    Thanks!
                      It seems that you have only posted part of the log, can you post the full log or e-mail it to us.
                      It may be that it is using a SCSI Disk Device driver, which doesn't support retrieval of SMART attributes.
