No problems with my PC but wondering is it worth running Memtest86?
  • dryden
    • Jul 2018
    Hey! First time here.
    I've heard about memtest for years on forums and other tech sites. Usually, it's brought up if there's a problem with a system that needs diagnosing.
    I haven't had any problems with my PC builds so far. Just wondering are there any benefits of running memtest on a system that has no problems?
    Thanks!
    If it is a home use PC and you are already using it without problems, then don't "fix" it until it is broken.
    • dryden
      • Jul 2018
      Got it! Thanks David!
