accuracy of CPU temp and mem speed
  • rayk
    • Mar 2019
    Memtest says running temp is between 110 and 120C. This can't be true can it?
    Also says we have 2400Mhz memory when we have 3000Mhz installed. Why the discrepancy?
    Thanks for your help.
    • 11127
    What version of MemTest86 are you using?
    What CPU is in the machine? Some CPUs are bizarre temperature offsets.
    2400Mhz report is likely correct.
    Send us a log file if you are using the latest software.
    • rayk
      • Mar 2019
      Where is the log file saved?
      • rayk
        • Mar 2019
        Not sure this is what you're looking for but it wouldn't let me upload the text doc or the html doc. The version is 8.1
          • 11127
          AMD designed this CPU to report the actual temperature with a 59C offset for this CPU model. We don't know why.
          But the next patch release of MemTest86 will take the offset into account.
          • rayk
            • Mar 2019
            Well that's helpful to know! Thanks for your help, I appreciate it.
