Test 8 Fail- Help to understand results
  • paul_a
    • Jul 2019
    Hi
    I have run the scan against all tests and the only errors were found in test 8. I then ran the test 8 again on each of the modules to try and work out which one of the two had failed (or whether both had). However on their own each module passed. Looking at the Troubleshooting memory error page, it says is likey mulit channel configuration is the problen due to either the motherboard is incompatiable or the RAM is mis matched.
    I haven't changed the RAM since I bought the laptop which are also of the same config. and the ram has worked in the Motherboard for years with no problem unitl recently, so it seems unlikely the RAM is uncompatible.
    So I was wondering, could it be something else? Could it be the CPU? I noticed
    at the end of the report below, under 'Last 10 errors' one of the 2 errors has a 2 next to CPU. What does this mean? Could it be my CPU is failing? Or
    do you thinkI just need to replace both modules and I should be all good.
    Paul
    System Information
    EFI Specifications 2.31
    System
    Manufacturer Notebook
    Product Name W250EGQ / W270EGQ
    Version Not Applicable
    Serial Number Not Applicable
    BIOS
    Version 4.6.5
    Release Date 01/07/2013
    Baseboard
    CPU Type Intel Core i5-3340M @ 2.70GHz
    CPU Clock 2694 MHz [Turbo: 3392.3 MHz]
    # Logical Processors 4 (2 enabled for testing)
    L1 Cache 4 x 64K (73901 MB/s)
    L2 Cache 4 x 256K (41377 MB/s)
    L3 Cache 3072K (26053 MB/s)
    Memory 8094M (16934 MB/s)
    DIMM Slot #0 4GB DDR3 PC3-12800
    Kingston / KHX1600C9S3/4GX / C028950E
    9-9-9-27 / 1600 MHz / 1.5V
    DIMM Slot #1 4GB DDR3 PC3-12800
    Kingston / KHX1600C9S3/4GX / BF28690E
    Result summary
    Test Start Time 2019-07-20 18:03:43
    Elapsed Time 0:12:18
    Memory Range Tested 0x0 - 22F600000 (8950MB)
    ECC Polling Enabled
    # Tests Passed 2/4 (50%)
    Lowest Error Address 0x58CB7FAC (1420MB)
    Highest Error Address 0x5F387FAC (1523MB)
    Bits in Error Mask 0000000000010000
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 8 [Random number sequence] 2/4 (50%) 2
    Last 10 Errors
    2019-07-20 18:09:19 - [Data Error] Test: 8, CPU: 2, Address: 58CB7FAC, Expected: 4CC6827B, Actual: 4CC7827B
    2019-07-20 18:05:38 - [Data Error] Test: 8, CPU: 0, Address: 5F387FAC, Expected: 91702F02, Actual: 91712F02
    • 11127
    CPU: 2
    CPU: 0
    This refers to the CPU core. But it isn't likely this is a CPU fault.
    Yes, it is certainly possible that you only see a problem in dual channel mode. Replacing both and having the errors disappear would prove this.
    It is also possible that the contacts on the slot lots were dirty, and re-seating the sticks cleaned up the connector and the problem is now gone.
    • paul_a
      • Jul 2019
      Thanks for your response. I did reseat the sticks and re run the test and got the same error. So I guess I will repalce both sticks of ram.
