USB become unrecognizable after 4 passed is done and restart into Window 10 ..
  • Origene55
    • Aug 2019
    • 8
    2 times in a row but same thing happen .. after the test is done the USB stick become unrecognizable when i boot back in Windows 10 .. it didn't show up in windows explorer & "Safely remove Hardware & Eject Media" either. I had to delete & repartition using Minitool Partition Wizard to make it detect by Windows again. How so & whats the solution ??
    By the way i had 6 errors after 4 passed. Is the ram still usable or it's time to get a new one ??
    Maybe your flash drive (hardware) is bad? Try a different flash drive.
    For the RAM errors see this page.
    • Origene55
      • Aug 2019
      • 8
      Alright but i can't find the explanation on that page about what i looking for :
      What is this (Lowest error address = 7129mb & Highest error address = 7129mb) mean ??
        That the range of memory addresses where the error(s) were encountered. As they are the same number (when rounded to the nearest MB) it means the fault is very localised.
        • Origene55
          • Aug 2019
          • 8
          I using 2 x Kingston 4GB DDR3 1333 stick & i having this "get errors only when testing RAM modules together, and not when individually tested" issue, these sticks are 8 yrs old but ram does not slow down over time right ?? Thanks
            Some errors only happen in dual channel mode.
            Correct, RAM does not slow down.
            But nothing lasts forever.
            • Origene55
              • Aug 2019
              • 8
              So the sticks still consider faulty even if they have errors only in dual channel mode ?? Thanks
                Could also be timing, voltage and BIOS firmware issues.
                • Origene55
                  • Aug 2019
                  • 8
                  I already order 2 x 8GB Kingston DDR3 1600MHz so let's see how it play out once i have it install. Let's hope it pass the test without any error even in dual mode.
                  • Origene55
                    • Aug 2019
                    • 8
                    Done testing with my new 2 x 8GB DDR3 1600Mhz & it's error free, looks like ram did get "old" over time for whatever reason. So it's time to retire my 4GB ram. Thanks for your time. Have a nice everyday.
