Need help 65535 errors during test 7! (And others)
  • rovaira
    • Mar 2014
    I sometimes get a random crashdump to a blue screen and then have to restart my computer. It states memcrash dump or something like that.
    I ran Memtest86 and here are the results:
    Intel I7-2600K 3.40 GHZ
    Time 8:30 Iterations 3 64 Bit Pass:2 Errors: 65535 (Ouch..)
    Error confidence value : 113
    Lowest Error Address 00206db2000 - 8301.6 MB
    Highest Error Address 0020edb4ff4 - 8429.7 MB
    Bit in error mesk: 00400000
    Bits in error - Total 1 Min 1 Max 1 Avg 1 Max Cont. errors 1
    Test 0 Errors 0
    Test 1 Errors 659
    Test 2 Errors 371
    Test 3 Errors 5751
    Test 4 Errors 23905
    Test 5 Errors 40227
    Test 6 Errors 5679
    Test 7 Errors 65535 + (uh..)
    Test 8 Errors 14104
    Test 9 Errors 5514
    Test 10 Errors 963
    So no idea what all this means other than some of my ram is probably bad.. I have 16 gigs of ram; which I believe is 4 sticks of ram. How do I know which need to be replaced?
    I also haven't been able to install IE 10 or 11 since there release which has been a LONG time.. I have no idea why. It just states fail everytime I try, yet Windows 7 installs the other updates.
    Anyone that is tech savy able to help me here? Thank you!
    (I went to device manager and I don't see my ram listed, but I do have 16 gigs.)
    • 11127
    Yes, it is likely the RAM (or the RAM slot) is bad.
    Try testing just 8GB at a time.
