Interpreting A Hard Crash after 1st pass complete with no errors
  • valueimagery
    • Feb 2022
    I certainly believe I have a hardware error somewhere with my Gigabyte Z490 i9 10900k 4x8GB 2400mhz Corsairs. I'm getting random crashes, with no Kernel Panics/BSOD while using the OS not under heavy load. Then boot loop crashes, sometimes 2-5 times until able to open the OS.
    After running two instances of memtest86 I'm getting a hard crash at the same point after completion of pass #1 and start of pass #2 in both tests.
    Is there anyway to interpret this? First step maybe test one stick/one slot at a time?
    Thanks for any insight.
    2022-02-04 05:56:00 - Finished pass #1 (of 4) (Cumulative error count: 0)
    2022-02-04 05:56:00 - Starting pass #2 (of 4)
    2022-02-04 05:56:00 - Running test #0 (Test 0 [Address test, walking ones, 1 CPU])
    2022-02-04 05:56:00 - MtSupportRunAllTests - Setting random seed to 0x96FBAA70
    2022-02-04 05:56:00 - MtSupportRunAllTests - Start time: 6685480 ms
    2022-02-04 05:56:00 - MtSupportRunAllTests - Enabling memory cache for test
    2022-02-04 05:56:00 - MtSupportRunAllTests - Enabling memory cache complete
    2022-02-04 05:56:00 - Start memory range test (0x0 - 0x10BE800000)
    2022-02-04 05:56:02 - MtSupportRunAllTests - Test execution time: 1.847s (Test 0 cumulative error count: 0)
    2022-02-04 05:56:02 - Running test #1 (Test 1 [Address test, own address, 1 CPU])
    2022-02-04 05:56:02 - MtSupportRunAllTests - Setting random seed to 0x50F39820
    2022-02-04 05:56:02 - MtSupportRunAllTests - Start time: 6687461 ms
    2022-02-04 05:56:02 - MtSupportRunAllTests - Enabling memory cache for test
    2022-02-04 05:56:02 - MtSupportRunAllTests - Enabling memory cache complete
    2022-02-04 05:56:02 - Start memory range test (0x0 - 0x10BE800000)
    2022-02-04 05:56:18 - MtSupportRunAllTests - Test execution time: 15.937s (Test 1 cumulative error count: 0)
    2022-02-04 05:56:18 - Running test #2 (Test 2 [Address test, own address])
    2022-02-04 05:56:18 - MtSupportRunAllTests - Setting random seed to 0x5A3900C6
    2022-02-04 05:56:18 - MtSupportRunAllTests - Start time: 6703568 ms
    2022-02-04 05:56:18 - MtSupportRunAllTests - Enabling memory cache for test
    2022-02-04 05:56:18 - MtSupportRunAllTests - Enabling memory cache complete
    2022-02-04 05:56:18 - Start memory range test (0x0 - 0x10BE800000)
    2022-02-04 05:56:29 - MtSupportRunAllTests - Test execution time: 10.554s (Test 2 cumulative error count: 0)
    2022-02-04 05:56:29 - Running test #3 (Test 3 [Moving inversions, ones & zeroes])
    2022-02-04 05:56:29 - MtSupportRunAllTests - Setting random seed to 0xAADF7280
    2022-02-04 05:56:29 - MtSupportRunAllTests - Start time: 6714256 ms
    2022-02-04 05:56:29 - MtSupportRunAllTests - Enabling memory cache for test
    2022-02-04 05:56:29 - MtSupportRunAllTests - Enabling memory cache complete
    2022-02-04 05:56:29 - Start memory range test (0x0 - 0x10BE800000)
    2022-02-04 08:41:18 - Finished pass #1 (of 4) (Cumulative error count: 0)
    2022-02-04 08:41:18 - Starting pass #2 (of 4)
    2022-02-04 08:41:18 - Running test #0 (Test 0 [Address test, walking ones, 1 CPU])
    2022-02-04 08:41:18 - MtSupportRunAllTests - Setting random seed to 0xBAFF249E
    2022-02-04 08:41:18 - MtSupportRunAllTests - Start time: 6675667 ms
    2022-02-04 08:41:18 - MtSupportRunAllTests - Enabling memory cache for test
    2022-02-04 08:41:18 - MtSupportRunAllTests - Enabling memory cache complete
    2022-02-04 08:41:18 - Start memory range test (0x0 - 0x10BE800000)
    2022-02-04 08:41:20 - MtSupportRunAllTests - Test execution time: 1.837s (Test 0 cumulative error count: 0)
    2022-02-04 08:41:20 - Running test #1 (Test 1 [Address test, own address, 1 CPU])
    2022-02-04 08:41:20 - MtSupportRunAllTests - Setting random seed to 0x6AFBB056
    2022-02-04 08:41:20 - MtSupportRunAllTests - Start time: 6677570 ms
    2022-02-04 08:41:20 - MtSupportRunAllTests - Enabling memory cache for test
    2022-02-04 08:41:20 - MtSupportRunAllTests - Enabling memory cache complete
    2022-02-04 08:41:20 - Start memory range test (0x0 - 0x10BE800000)
    2022-02-04 08:41:36 - MtSupportRunAllTests - Test execution time: 15.916s (Test 1 cumulative error count: 0)
    2022-02-04 08:41:36 - Running test #2 (Test 2 [Address test, own address])
    2022-02-04 08:41:36 - MtSupportRunAllTests - Setting random seed to 0x5846820E
    2022-02-04 08:41:36 - MtSupportRunAllTests - Start time: 6693551 ms
    2022-02-04 08:41:36 - MtSupportRunAllTests - Enabling memory cache for test
    2022-02-04 08:41:36 - MtSupportRunAllTests - Enabling memory cache complete
    2022-02-04 08:41:36 - Start memory range test (0x0 - 0x10BE800000)
    2022-02-04 08:41:47 - MtSupportRunAllTests - Test execution time: 10.459s (Test 2 cumulative error count: 0)
    2022-02-04 08:41:47 - Running test #3 (Test 3 [Moving inversions, ones & zeroes])
    2022-02-04 08:41:47 - MtSupportRunAllTests - Setting random seed to 0x843809E4
    2022-02-04 08:41:47 - MtSupportRunAllTests - Start time: 6704076 ms
    2022-02-04 08:41:47 - MtSupportRunAllTests - Enabling memory cache for test
    2022-02-04 08:41:47 - MtSupportRunAllTests - Enabling memory cache complete
    2022-02-04 08:41:47 - Start memory range test (0x0 - 0x10BE800000)
    Seems likely this is a hardware fault.
    Sudden reboots / lockups / shutdowns are very hard to debug for a home user.
    Without a team of experienced hardware engineers and some high end test equipment you are left with trial and error. Basically taking a guess and swapping components in and out until the problem is solved. But start with the easy step of checking if there is updated BIOS firmware.
    See also this page
