Memtest86 => Exit => A2 problem... pls help :(
  • Panormalix
    • Apr 2015
    I am sorry but I am not English and so I use a translator to chercherune answer.
    I made a bootable USB key with memtest to check my memory for a problem that I solved the meantime.
    This morning, having forgotten that the key was still connected to my computer, it runs the test on boot, and surprised, I chose the "Exit" option that the program offers.
    I then unplug the key to leave my computer redémarer normally and the catastrophe black screen at startup with a simple "A2" at the bottom right of the screen.
    I try to make a clearsmos, unplug some of my memory modules.
    Thank you in advance if you find the answer to my problem.
    A2 is an error produced by some MSI motherboards when the hard drives can't be detected (IDE error).
    - Check the boot order in BIOS is correct.
    - Check the cabling to the hard drives is OK.
    - If you have multiple hard drives (or CD / DVD drives) disconnect them all except the boot drive
    - Update the BIOS, as it seems there are bugs in some of the MSI BIOS releases.
