Hey there guys. Quick question. I've put the latest version of MemTest86 onto my flash drive but it continually boots into V4.3.7 rather than V.6.1.x.
I noticed the note in Technical Information stating if your machine doesn't support UEFI then it will boot into V4. Well I'm pretty sure the P8P67 Deluxe motherboard supports UEFI. When I choose which device to boot from I get the choice of Sandisk, UEFI Sandisk, and a second entry for UEFI Sandisk.
I've been using the regular Sandisk option so I assume that is why it keeps booting with V4. Should I try the other UEFI Sandisk selections to get V6.1.x to run? Why do two options for UEFI Sandisk appear?
Thank you!
Thank you!
