memtest86 doesn't boot in macbook pro 8,1 in uefi mode.
  • garegin
    • Jul 2015
    It goes to a black screen and then gets stuck.
    There is a firmware compatibility issue with Mac's. We were able to workaround the issue with a fix.
    See this thread for an unofficial patch:
    http://www.passmark.com/forum/showth...tina-questions
    • garegin
      • Jul 2015
      thanks for that. Now, it gets stuck at the screen with the last message "Getting SPD Details"
        Can you E-mail us the log file
        A log file (MemTest86.log) is automatically created and updated while MemTest86 v6 is running. This file is saved in the 'EFI/BOOT' directory in the USB drive's first partition.
        • garegin
          • Jul 2015
          ok. I just emailed it.
          • garegin
            • Jul 2015
            ok. another flash drive fixed the issue. but the first flash works fine, otherwise. it's probably a bug too, vendor specific to different flash models.
