Inconsistent SPD info detected
  • memetic
    • May 2024
    • 19
    Under: "System (I)nfo > View detailed RAM (SPD) info > Slot [x] > page 1 field [Type detail]" I see "Synchronous, Unbuffered (Unregistered)", but on the page 3 I see the field "Registered: Yes"
    I don't understand why these disagree.
    Are they referring to different RAM attributes, or does it indicate that the manufacturer has written incorrect information into the SPD EEPROM?
    • 11127
    What are the correct details for the RAM (according to the specs?)
    Can you post a debug log?
      • 11127
      Some additional information:
      The text "Synchronous, Unbuffered (Unregistered)" comes from SMBIOS. That is to say the text is set by the machine's firmware.
      The value on Page 3 comes from SPD data.
      So likely there is a firmware/SMBios bug on your machine. You could report it to the system vendor, but they probably won't care.
      • memetic
        • May 2024
        • 19
        According to this Samsung m393a2k43bb1-crc they should be "Registered" with ECC.
        I have always been confused about the difference between "registered" and "buffered" - are these one and the same?
        Attached.
        The txt file is what MemTest86 showed in the detailed SPD info screens.
        • memetic
          • May 2024
          • 19
          ..."Synchronous, Unbuffered (Unregistered)" comes from SMBIOS...set by the machine's firmware...likely there is a firmware/SMBios bug on your machine. You could report it to the system vendor, but they probably won't care.
          I will report it. I have an ongoing email conversation with ASRockRack too. They have so far actually been supportive.
