A problem with OSFMount on Win7 Professional 64bit.
  • uyiab
    • Jul 2011
    I met a problem with OSFMount on Win7 Professional 64bit.
    Install file was downloaded from URL:
    http://www.osforensics.com/downloads/osfmount_x64.exe
    After installation, I tried to mount attached IMAGE file (EXT2), but it seems that the file can’t be recognized normally.
    (File system is N/A.)
    Also, when I tried to open F driver, error dialogue displayed notifying that the driver can’t be recognized.
    With the same IMAGE file, it can be mounted successfully under Windows XP environment by OSFMount 32bit.
    Would you please give some advice for this issue?
    the image create by:
    # dd if=/dev/zero of=disk.img bs=1M count=10
    # mkfs.ext2 -F disk.img
    Best Regards,Baiyu
    Currently, OSFMount does not support any file system that Windows does not support. OSFMount simply creates a virtual disk backed by the contents of the image file. It is up to Windows file system drivers to recognize the file system on the image. So I find it odd that you were able to mount an EXT2 image on Windows XP. Perhaps there is a 3rd party EXT2 driver installed on your XP system?
    Anyways, we are looking at support for non-Windows file systems for a future release.
    Keith
