OSFMount - commandline problem
  • Hopik
    • May 2017
    Hello, I want mount virtual usb drive wiith OSFMount automatically at start of windows, so I am trying to create .bat file with proper commandline params of OSFmount.com. But when I execute my command line, USB image is mounted but without any content - similar behavior like whe I do it in GUI app and I have not selected "Mount all partitions". So my question is: how to set "Mount all partitions" in commandline?
    My commandline:
    OSFMount.com -a -t file -f c:\temp\USB.bin -m F: -o rem,rw,hd
    I already tried to play with -v param but with -v 0 i got only help text and with -v 1 i got message: Error: Partition table not found
    Note. USB image was created with ImageUSB
    Thx for help
    • 11135
    USB drives don't normally have partitions. So maybe there are no partitions? As this would also explain the 'Partition table not found' message.
    • lauzona
      • Apr 2015
      • 26
      Hi
      My commandline:
      Thx for help
      try a partition manager lile gparted:
      http://gparted.org
      make a small partition like 1 mb and a second one with hole rest format last one with filesystem you need
      now the Stick have a partition Table, try again a mount be aware that you must use partition 1 (normal start with zero) if that not work try 2
      best
      Andre
