OSForensics 2 Searching Index for a Phrase
  • alexm
    • Feb 2013
    I just upgraded to version 2 to fix an issue I had opening attachments/emails. This has been fixed but now I can't seem to search for phrases. Before "this phrase" would bring up results whereas now it produces zero results.
    Any suggestions? Would appreciate an urgent reply on this as I am now effectively dead in the water.
    thanks
    Alex
    Edited to add that I have purchased the software.
    • 11135
    Yes I can confirm it looks like we broke it.
    In V2, we moved the search engine function inside the main OSF application, as opposed to being an external .exe that was called. With caching this gave a big lift in performance. It shouldn't have broken anything.
    It should be an easy fix.
    The V2 index files should still work with V1.2 of the software. So going back to V1.2 should be a work around.
    It is Saturday here at the moment, but on Monday we'll release a fix for it.
    • alexm
      • Feb 2013
      Ok that's great, thank you!
      I am currently working around this by doing the searches in v1.2 and then reviewing the results in v2!
      Alex
        • 11135
        This should now be fixed in a patch release, V2.0.1001.
        Available for download at the usual place,
        http://www.osforensics.com/download.html
        Just install over the top of any old release.
        • alexm
          • Feb 2013
          Thank you! All sorted now
