Advise request for system
  • Repchan
    • Jun 2010
    hello friends.
    here is system's configuration i am going to buy.
    this is my 2nd PC and want to hear some advises from competent people.
    as my budget has limitations i have selected not very expensive components:
    1)
    Video Card - GTX 260 /896 MB / 448-bit
    CPU - Intel/ Core i5/ 750 2.66GHz, 8MB, Box, LGA1156
    MB - LGA 1156/ Asus/ P7P55 LX P55 2PCIX 3 PCI +2PCIe 4DDR3 GLAN raid
    MEMORY - DDR3 DIMM 240pin/ 1024MB/ 1333 Kingston KVR1333D3N9/1G - 2PCS
    POWER SUPPLY - ASUS P55GA 550W
    HDD - 320GB/ Seagate ST3320613AS Barracuda 16mb 7200rpm NCQ
    2)
    Video Card - PCI Express 1GB/ Asus/ EAH5770 CUCORE / 2DI/1GD5 Radeon HD GDDR5 128-bitCPU - Intel/ Core i5/ 750 2.66GHz, 8MB, Box, LGA1156
    MB - MSI P55-CD53
    MEMORY - GOODRAM GR1333D364L9/2G; DDR3 2GB (1333MHz) - 1PCS
    so which system will be more GAME -able?
  • wonderwrench
    • Oct 2007
    • 264
    I would never build a PC with less than 4 gigs of ram if you want to play games or do much of anything in this day and age. The second system only has a single 2 gig stick which will cripple its performance even more do to lack of memory bandwidth. I would suggest dropping down to a lower cost CPU and or GPU and spending the money saved on more memory. Doing so would give you a more balanced system. If you must have a quad core CPU I'd recommend building a AMD system.
    As far as the Video card choice it depends on several factors. What OS are you going to run? What games do you intend to play because some games like ATI cards and some like Nvida cards.
    Can you give me a figure in US dollars you have to spend? Links to the resellers you plan on using?
    Bill
