Fail - Phenom II x4 940
  • wonderwrench
    • Oct 2007
    • 264
    #16
    Originally posted by hercules
    All the memory bar this 1 stick has been rma'd to ebuyer.
    Crucial 4GB Kit (2x2GB) DDR2 800MHz/PC2-6400 Memory CL6 1.8V
    Qty: 2 will be fitted tomorrow morning.
    Once fitted I will run another test, I just hope to God there is a noticeable improvement.
    So your going to run 8 gigs? Four 2 gig modules? If so keep track of each pair (kit). Mark one kit some how, marker tape etc. Place one pair (kit) in the blue slots and the other kit in the white slots. It is not uncommon to have stability problems running all slots populated at full rated speed. If you have problems. Try manually setting the memory to 666 mhz instead of 800 mhz.
    Bill
    • hercules
      • Sep 2010
      • 13
      #17
      Hi Bill
      Thanks for your reply, and I will take take your advice. mem should be here any minute. I hope I do not need to mess around with voltage, what happend to the good old days when we added mem and it worked?
      Im wary of running a new test incase its not a good score but hey got to live a little at times also. Will post back once installed.
      • hercules
        • Sep 2010
        • 13
        #18
        This is my system.
        [CPU]----------[AMD Phenom II BE x4 965 @ 3.4 Ghz]
        [MainBoard]----[ASUS Crosshair II Formula Republic of Gamers Series nForce 780a SLI]
        [Bios]---------[2607] Default sETTINGS
        [GFX]----------[Nvidia 9600GT]-258.96 WHQL
        [RAM]----------[x4 2GB DDR2 PC2-6400 @ 800 Mhz]
        [PSU]----------[Scythe Stronger 700w]
        [Cooling]------[Zalman CNPS9900A-LED]
        [Display]------[Dual 20inch Acer moniters]
        [HDDs]---------[x2 Western Digital]
        [Case]---------[NZXT Hush Black Silent Case]
        [OS]-----------[Windows 7 Ultimate]
        [OC]-----------[Not Overclocked]
        This is my screenshot
        This is my problem 547.4
        HELP! please.
          CPU result (among others) is low. Are you running on all cores? Also check the PerformanceTest Edit / Preferences window to see that you are running at least 4 processes.
          • wonderwrench
            • Oct 2007
            • 264
            #20
            Also did you do a clean install of windows 7 after you changed CPU's? If not windows may be confused. Take a look in device manager under processors.
            Does it list the correct name for all four cores? If not delete all cores and reboot. Your CPU, Memory and CD scores are really low. The memory score being low could be caused by the low CPU performance. What type of CD/DVD are you using for the CD test? Best results are obtained using a pressed DVD.
            A original (pressed) windows Vista or Windows 7 install DVD is what I use and it works well. My HTPC score for comparison.
            Bill
            • hercules
              • Sep 2010
              • 13
              #21
              Tried a different Mobo...
              Seems the Mobo was the issue, so 1638.7
              Gigabyte GA-MA770-UD AMD Phenom II X4 965 3415 BL277316
              • hercules
                • Sep 2010
                • 13
                #22
                1638.7
                Is this what i should be getting?
                • wonderwrench
                  • Oct 2007
                  • 264
                  #23
                  1638.7
                  I did some searching and your results look about right. Have you tried searching for baselines using "Find Same CPU+Video Card" in download baselines?
                  • wonderwrench
                    • Oct 2007
                    • 264
                    #24
                    Hey any updates on your system? Hope it running good for you.
                    Bill
