Difference in small letters in gfx cards
  • nix
    • Jun 2011
    hello, I'm looking for a gaming laptop.
    MSI GX640, 740 or something else but when looking at the benchmark charts for high end gfx card i see many "almost same cards but big diff on rating"
    => Mobility radeon HD 5870 (rating =1273) or radeon HD 5870 (2717)
    But especially the GTX460 gfx has many more:
    GeForce GTX 460M1,206,
    WinFast GTX 4602,590,
    GeForce GTX 4602,354,
    GeForce GTX 460 SE2,089,
    and then there's something with SLi ( those U can set cards dual? means u can buy extra card for that?)
    - Can anyone explain the differences between all this?
    - What is most important when looking for gaming laptop?
    I read the gfx card u should invest most, rest wont make that much difference - i7 vs i5 compared to good gfx card.( atm i play with inspiron 6400 and it has lot of troubles as u can imagine
    - What can be upgraded usually in laptop?
    When I buy a not-integrated vid card, means I can always upgrade with anything? if I buy 2x2 gb Ram can I upgrade with 2x 8 or 2x 16 later if needed? guess Cpu can't be?
    Ty for all yr patience for reading this
    Greets Nix
    The Radeon HD 5870 is a large desktop video card. The Mobility 5870 is a small card for laptops. AMD shouldn't have given them the same model number.
    Different manufacturers come out with different cards based on the same nVidia or AMD chips and then often name them slightly differently.
    If you are just buying this for gaming, they can you get a desktop. You get more power for your dollar with a desktop. Laptops have heat problems with the high end video cards. Plus you can generally only upgrade the RAM in a laptop. I don't know of any laptop where you can upgrade the video card later on.
    • nix
      • Jun 2011
      Ty for quick response,
      wife don't want no desktop in house ever again so no doubts there...
      So only the "M" or mobility cards are for laptops? Narrows it all a bit down so that's a good thing in the end
      Atm I'm looking at a BTO site: assembling yr own laptop. Comparing this vs GX740 and N53SV ty for yr time already here )
      example what im thinking of atm:
      P•BOOK 15CL35-GT555 QUAD USB 3.0 / FULL HD / GT555 2GB
      Beeldscherm: 15.6 inch FULL HD LED Glare TFT, (resolutie 1920x1080) **NON-Glare + Protector (15 inch): Uw scherm wordt onspiegeld (dus geen glinsteringen meer) + voorzien van een screen protector.
      Videokaart: NVIDIA® GeForce® GT555 2Gb GDDR3 + Optimus Technologie (batterij-besparing via Intel HD Graphics)
      Videokaart: Intel® HD Graphics (2e energiezuinige videokaart), wordt ingeschakeld als NVIDIA wordt uitgeschakeld.
      **Batterij 15CL35 - 17CL35: 9 Cell hoge capaciteit batterij, 11.1Volt - 5600mA - 62.16Wh (circa 30% langere batterijduur)
      Chipset: Mobile Intel® HM65 Express Chipset
      Processor Sany Bridge (max 45W - QUAD): Intel® Core™ i7-2630QM 6Mb Cache, 2.00 GHZ (2.9GHZ Turbo mode / Quad Core - 8 threads)
      **Processor koeling: Artic Silver koelpasta (Systeem wordt beter gekoeld, tot 6 graden winst)
      **RAM DDR3 1333 (1): 4GB Kingston HyperX High Performance Gaming DDR3-1600MHz (slot 1)
      **RAM DDR3 1333 (2): 4GB Kingston HyperX High Performance Gaming DDR3-1600MHz (slot 2)
      Harddisk: 500GB 7200 rpm 16Mb cache (Max MB/s 80 lezen / 75 schrijven)
      Optische disk SATA: 8x DVD+/-RW Dual Layer + DVD-RAM
      DVD-Software: DVD Software optioneel
      **Wireless + Bluetooth Combo: BTO® Wireless, Single Band BGN (2.4GHz), 300MB + Bluetooth combinatiekaart
      USB 3.0 - 2.0: 2 x USB 3.0 + 2 x USB 2.0 (USB 3.0 poorten ook te gebruiken voorUSB 2.0 apparatuur)
      UMTS/3G/3.5G: UMTS - 3G Optioneel
      VGA-poort: 1 x D sub 15-Pin VGA poort
      HDMI Poort: HDMI aansluiting voor extern LCD scherm / HD TV
      Webcam: Ingebouwde 1,3 MegaPixel WebCam + Microfoon
      E-SATA Poort: Externe SATA aansluiting voor snelle schijven
      Keyboard: Notebook keyboard incl Numeriek keypad
      **Keyboard Layout: AZERTY Toetsenbord (BE-Internationaal voor Belgie/Fr.)
      LAN: 10/100/1000 GigaBit Ethernet (RJ45)
      Cardreader: 7-in-1 card Reader (MMC/SD/MiniSD/MS/MS-Pro/MS-Duo/MS-DuoPRO)
      Audio: Realtek geluidskaart met HD Audio ondersteuning
      Audio: Microfoon-ingang, Speaker uitgang + Digitale uitgang (SPDIF) Audio: Ingebouwde Stereo speakers
      Afmetingen: 374mm (B) x 250mm (D) x 25mm~37mm (H)
      Gewicht: 2.6 Kg
      Garantie: 2 jaar carry in garantie
      AKTIE: GRATIS BTO Draagtas + USB muis + muismat + stereo oordopjes twv 39 euro
      Subtotaal excl. BTW € 869
      BTW 19 %
      Totaalprijs incl. BTW € 1034,11
        Tell her you are getting a blu-ray player, and then buy a PC in a media center box. And stick it under the TV. She'll never know what's inside.
        • nix
          • Jun 2011
          No need to lie to her, she agrees on me buying a new laptop for gaming, that's already something to give back some respect on my side.
          What ye think of the former list of laptops? any suggestions there?
            Don't need to lie. Just need to give a good sales pitch
            CPU is good. RAM is good.
            Not sure about the video, as I am somewhat out of touch with the current best mobile video. But this is critical for a gaming laptop. So do some research.
            Disk is OK (for a laptop). An SSD would be much faster but you are going to need the capacity of a traditional drive.
            You might want to consider a blu-ray drive. They will be more or less standard in 12 months. You have a HDMI port on the machine, so you could connect the laptop up to your TV for movies / games.
            • nix
              • Jun 2011
              tyvm for the help
