Upgrading My System
  • nightmare
    • Feb 2014
    Upgrading My System
    This is My current System:
    PassMark Software - Display Baseline ID# 206448
    I'm thinking of upgrading it,what should i consider upgrading first to get better performance(budget right now is $100) ?
    I would save your money until you can afford a new motherboard and CPU.
    • nightmare
      • Feb 2014
      You mean Intel right? I thought of getting 2 sticks of RAM or an extra SSD for a RAID '0'.
        RAID doesn't add a huge amount of performance to what is already a reasonable SSD.
        8GB is already enough for most applications. Check in task manager to see how much RAM you currently use and have free during typical daily use. I would bet you aren't using 8GB. I only use around 3GB (with about a dozen apps running).
        • nightmare
          • Feb 2014
          Cool,then i will wait for some time until i get some money or see how the Streamroller turns out.
