I've just downloaded and tested my system and except for the 2D score I'm not surprised since it is an older computer.
However, the 2D scores are puzzling. I hope you can help me to understand what is going on.
System data:
Operating System: Windows 7 Ultimate Edition Service Pack 1 build 7601 (64-bit)
CPU Type: Intel Core i7-2600K @ 3.40GHz (o/c 4.5GHz)
Number of CPUs: 1
Cores per CPU: 4
Hyperthreading: Enabled
Motherboard: P8Z77-V LK
Memory: 16GB Kingston DDR3 SDRAM
Videocard: AMD Radeon RX 470
Hard Drive: INTEL SSDSC2KW256G8 (256GB)
CPU Mark 7230
2D Mark 20.1
3D Mark 6845
Memory Mark 2923
Disk Mark 4632
These 2D ratings are lower than I expected
Image Filters 262.4
Image Rendering 0.84
Direct 2D 15.3
Image filters test gives a warning, "Failed to create Direct3D environment..."
(Monitor has no portrait mode. No such error occurs in the 3D Mark DirectX tests.)
These tests look more "normal":
Simple Vectors 30.4
Fonts and Text 201.2
Windows Interface 105.8
There is apparently not enough data for this model gpu to compare with.
What can I look for (and possibly fix) as a potential issue to cause this low 2D performance?
System data:
Number of CPUs: 1
Cores per CPU: 4
CPU Mark 7230
2D Mark 20.1
3D Mark 6845
Memory Mark 2923
Disk Mark 4632
Image Filters 262.4
Direct 2D 15.3
Simple Vectors 30.4
