CD Read questions (and my score posting - 1772.7)
  • Leo Brennan
    • Nov 2007
    • 15
    Hello....
    I've noticed a huge variation in scoring when it comes to CD Read scores (when looking at some of the baselines i have compared my system to). I'm trying to figure out how I can make mine faster (if possible). My DVD Burner is an Asus QuietTrack with SATA interface. my score ranges from sub 1 all the way up to 9 in change. The variations I have noticed in my own system are directly related to the type of disc I have in the drive. If i have a CD in there, I get horrible scores. DVDs are a different matter though. With some DVDs, I can get in the 9's, while others give me a 4 or 5 rating. So far, the best DVD I can have in the drive when doing the test is my Office Enterprise 2007 DVD from Microsoft. This particular disc yields the highest score for me. I've also noticed that if I run the CD Read test a second time immediately after running a first test (while the drive is still spinning) I get a better score (almost doubled in some cases).
    I guess my question, for anyone who may care to answer, is why ??? Is the test supposed to behave like this? A final question for anyone reading this that may have a high CD read score........ what are you running to get an insanely high score? I've posted my results below:
    PassMark(TM) PerformanceTest 6.1 (http://www.passmark.com)
    Results generated on: Wednesday, November 21, 2007
    Benchmark Results
    Test Name: This Computer
    CPU - Integer Math: 673.0
    CPU - Floating Point Math: 2354.2
    CPU - Find Prime Numbers: 1930.6
    CPU - SSE/3DNow!: 15986.0
    CPU - Compression: 17826.5
    CPU - Encryption: 101.4
    CPU - Image Rotation: 3354.2
    CPU - String Sorting: 12294.3
    Graphics 2D - Lines: 119.2
    Graphics 2D - Rectangles: 78.1
    Graphics 2D - Shapes: 53.8
    Graphics 2D - Fonts and Text: 243.2
    Graphics 2D - GUI: 169.3
    Graphics 3D - Simple: 2585.7
    Graphics 3D - Medium: 715.7
    Graphics 3D - Complex: 77.3
    Memory - Allocate Small Block: 3209.2
    Memory - Read Cached: 2790.5
    Memory - Read Uncached: 2797.2
    Memory - Write: 2504.2
    Memory - Large RAM: 1113.2
    Disk - Sequential Read: 63.1
    Disk - Sequential Write: 50.2
    Disk - Random Seek + RW: 2.4
    CD - Read: 8.1
    CPU Mark: 4583.1
    2D Graphics Mark: 478.2
    Memory Mark: 917.8
    Disk Mark: 418.3
    CD Mark: 996.7
    3D Graphics Mark: 1081.3
    PassMark Rating: 1772.7
    Number of CPU: 1
    (4 Core(s)/CPU, 1 Logical(s)/Core)
    CPU Type: Intel(R) Core(TM)2 Extreme CPU X9650 @ 3.00GHz
    CPU Speed: 3672.3 MHz
    Cache size: 6144KB
    O/S: Windows Vista (WIN32)
    Total RAM: 3326.3 MB.
    Available RAM: 2394.6 MB.
    Video settings: 1920x1200x32
    Video driver:
    DESCRIPTION: GeForce 8800 Ultra
    MANUFACTURER: NVIDIA GeForce 8800 Ultra
    BIOS:
    DATE: 04/18/07
    Drive Letter: C
    Total Disk Space: 698.6 GBytes
    Cluster Size: 4.0 KBytes
    File system: NTFS
    Thanks in advance for any replies, and Happy Thanksgiving!
    -Leo
  • Leo Brennan
    • Nov 2007
    • 15
    updated score --- 1800
    below are my new scores.....didn't change a thing, just ran some of the tests individually after my original posting...
    Benchmark Results
    CPU - Integer Math: 694.4
    CPU - Floating Point Math: 2667.4
    CPU - Find Prime Numbers: 1929.9
    CPU - SSE/3DNow!: 16147.0
    CPU - Compression: 17870.1
    CPU - Encryption: 101.6
    CPU - Image Rotation: 3364.8
    CPU - String Sorting: 12388.0
    Graphics 2D - Lines: 120.6
    Graphics 2D - Rectangles: 79.4
    Graphics 2D - Shapes: 54.0
    Graphics 2D - Fonts and Text: 266.8
    Graphics 2D - GUI: 169.1
    Graphics 3D - Simple: 2589.6
    Graphics 3D - Medium: 712.6
    Graphics 3D - Complex: 75.5
    Memory - Allocate Small Block: 2770.2
    Memory - Read Cached: 2813.7
    Memory - Read Uncached: 2812.1
    Memory - Write: 2525.3
    Memory - Large RAM: 1082.6
    Disk - Sequential Read: 61.2
    Disk - Sequential Write: 51.1
    CD - Read: 9.5
    CPU Mark: 4643.3
    2D Graphics Mark: 496.3
    Memory Mark: 887.5
    Disk Mark: 414.9
    CD Mark: 1160.3
    3D Graphics Mark: 1081.0
    PassMark Rating: 1800.0
    Number of CPU: 1
    Cache size: 6144KB
    Available RAM: 2432.1 MB.
    Video driver:
    BIOS:
    DATE: 04/18/07
    Drive Letter: C
    File system: NTFS
    -Leo
      Yes, the CD test results can vary depending on the media used. Using a CD with many small files will give a poor result. Using a DVD with a small number of large files will give a better result. This is normal. Large files can be read quicker as there is less seeking. We suggest people use standard discs, but of course not everyone does this.
      1800 is a big result, but you have a high end quad core CPU that seems to be overclocked and a nice graphics card. So a big result is to be expected.
        You should post your result to our database. See,
        http://www.cpubenchmark.net/overclocked_cpus.html
        We don't have any examples of a overclocked X9650. It would make a good addition.
        You can do this from the PerformanceTest menu item,
        Baselines / Upload Baseline to Web.
        • Leo Brennan
          • Nov 2007
          • 15
          updated score (2005.1) ....overclocked to 4.2GHz
          Here are my latest scores. Got my system overclocked to 4.2 GHz now, and appears to be stable. could probably go higher, but i'm gonna ghost my system before tinkering with anything else to push it further (soem files became corrupt in windows during other bothed attempts during my overclocking endeavours). see below:
          Results generated on: Friday, November 23, 2007
          Benchmark Results
          CPU - Integer Math: 799.4
          CPU - Floating Point Math: 3073.0
          CPU - Find Prime Numbers: 2234.4
          CPU - SSE/3DNow!: 18520.7
          CPU - Compression: 20716.5
          CPU - Encryption: 117.5
          CPU - Image Rotation: 3887.8
          CPU - String Sorting: 14322.3
          Graphics 2D - Lines: 139.4
          Graphics 2D - Rectangles: 91.5
          Graphics 2D - Shapes: 61.5
          Graphics 2D - Fonts and Text: 290.2
          Graphics 2D - GUI: 186.2
          Graphics 3D - Simple: 2607.7
          Graphics 3D - Medium: 725.6
          Graphics 3D - Complex: 88.3
          Memory - Allocate Small Block: 3259.9
          Memory - Read Cached: 3224.2
          Memory - Read Uncached: 3236.7
          Memory - Write: 2544.4
          Memory - Large RAM: 1171.5
          Disk - Sequential Read: 62.6
          Disk - Sequential Write: 49.9
          Disk - Random Seek + RW: 2.6
          CD - Read: 8.2
          CPU Mark: 5346.6
          2D Graphics Mark: 557.7
          Memory Mark: 993.4
          Disk Mark: 416.4
          CD Mark: 999.3
          3D Graphics Mark: 1095.0
          PassMark Rating: 2005.1
          Number of CPU: 1
          CPU Speed: 4234.7 MHz
          Cache size: 6144KB
          Available RAM: 2351.4 MB.
          Video driver:
          BIOS:
          DATE: 04/18/07
          Drive Letter: C
          File system: NTFS
          I'll post them to the web now as well.
          -Leo
          • Leo Brennan
            • Nov 2007
            • 15
            tweaked numbers....
            just read your posting in the forums about adjusting performance options in windows (advanced tab under system properties). wow!! my 2D numbers are not so bad now. the only thing i changed was this option (adjust for best performance) and ran the test again. i jumped by over 58 points! sweet!!
            Benchmark Results
            CPU - Integer Math: 799.9
            CPU - Floating Point Math: 3081.7
            CPU - Find Prime Numbers: 2239.5
            CPU - SSE/3DNow!: 18525.0
            CPU - Compression: 20718.1
            CPU - Encryption: 118.1
            CPU - Image Rotation: 3911.3
            CPU - String Sorting: 14375.4
            Graphics 2D - Lines: 140.1
            Graphics 2D - Rectangles: 135.8
            Graphics 2D - Shapes: 62.9
            Graphics 2D - Fonts and Text: 553.0
            Graphics 2D - GUI: 251.0
            Graphics 3D - Simple: 2758.3
            Graphics 3D - Medium: 781.2
            Graphics 3D - Complex: 91.4
            Memory - Allocate Small Block: 3644.5
            Memory - Read Cached: 3245.6
            Memory - Read Uncached: 3249.2
            Memory - Write: 2556.7
            Memory - Large RAM: 1185.2
            Disk - Sequential Read: 63.7
            Disk - Sequential Write: 51.0
            CD - Read: 8.4
            CPU Mark: 5357.1
            2D Graphics Mark: 796.3
            Memory Mark: 1026.3
            Disk Mark: 424.0
            CD Mark: 1032.2
            3D Graphics Mark: 1162.0
            PassMark Rating: 2059.8
            Number of CPU: 1
            CPU Speed: 4237.4 MHz
            Cache size: 6144KB
            Available RAM: 2382.6 MB.
            Video driver:
            BIOS:
            DATE: 04/18/07
            Drive Letter: C
            File system: NTFS
            I think I am gonna push it even further tonight, after dinner.
            -Leo
            • Leo Brennan
              • Nov 2007
              • 15
              top 10 question
              I've uploaded a few different baselines from slightly different configurations. I'm not seeing this processor listed in your CPU chart though. Is there a reason for that? Perhaps you only include "non-overclocked" CPUs there? Also, what is the top ten when you install baselines from the web? I thought the top ten was for overall score, no? If so, my baseline (BL8760) is not showing up there. My score should be showing up at number 9 i think (score of 2324) as it is higher than 2 scores that appear there right now. Also, if it goes by CPU, then i should appear there as well (cpu score is 5581.5) which beats out 4 of the ones listed in there right now. Anyway, I'm just curious as to how the top 10 get selected. Thanks, and have a happy holiday season.
              -Leo
                At the moment I beleve this machine is #2 in the overclocked CPU chart.
                and #10 in the overall charts
                http://www.passmark.com/baselines/topten.php
                We were filtering results that had silly looking CD scores in the past (to filter out people using RAM disks as CD drvies). We raised the level a bit today, so this might be why you didn't initially appear.
                We would prefer it is you only submitted results once. From time to time, we delete the duplicates that we come across that looks like it is from the same machine.
                • Leo Brennan
                  • Nov 2007
                  • 15
                  ok, thanks
                  Ok, I understand. When I get back home, I can post in here the other basline numbers i uploaded so you guys can delete the older ones if you want. Also, the link for the top 10 u gave me is right on, however, what is the following list:
                  Current Top Ten List
                  #1 [Dual CPU] Intel Xeon X5365 @ 3.00GHz
                  #2 [Dual CPU] Intel Xeon X5355 @ 2.66GHz
                  #3 [Dual CPU] Intel Xeon E5345 @ 2.33GHz
                  #4 [Quad CPU] Dual-Core AMD Opteron 8218
                  #5 [Dual CPU] Intel Xeon E5320 @ 1.86GHz
                  #6 Intel Core2 Quad @ 2.93GHz
                  #7 [Dual CPU] Intel Xeon 5160 @ 3.00GHz
                  #8 Intel Core2 Extreme Q6850 @ 3.00GHz
                  #9 Intel Core2 Extreme Q6800 @ 2.93GHz
                  #10 [Dual CPU] Intel Xeon 5150 @ 2.66GHz
                  This one is on the same page as the graphs for all the CPUs (linked from your thread on How do I push my PC to the bleeding edge?). This was the top ten list i was referring to. Until you sent that link for this different top ten, I didn't even know that page existed. Thanks again. After the holidays, I'll be pushing this machine more. Hope I don't break anything. hahaha. Happy Holidays!
                  -Leo
                    I think that is the current top CPU list for non overclocked machines. As you are overclocking, you in the overclocking list and not in the normal list.
