top ten bound?? (2223.6 rating and climbing)
  • Leo Brennan
    • Nov 2007
    • 15
    I'm messing around with overclocking and different media for the CD Read test. Right now, I have a score of 2223.6....... and I have not yet hit the limit on overclocking (i think). Also, if I have any better media for the CD read test, I should be able to pop into the top ten soon. Only 45 points away from the number ten spot. hehehehe
    here is my stuff:
    PassMark(TM) PerformanceTest 6.1 (http://www.passmark.com)
    Results generated on: Saturday, November 24, 2007
    Benchmark Results
    Test Name: This Computer
    CPU - Integer Math: 822.9
    CPU - Floating Point Math: 3155.1
    CPU - Find Prime Numbers: 2294.7
    CPU - SSE/3DNow!: 18977.4
    CPU - Compression: 21251.0
    CPU - Encryption: 120.4
    CPU - Image Rotation: 3984.4
    CPU - String Sorting: 14786.8
    Graphics 2D - Lines: 142.5
    Graphics 2D - Rectangles: 151.9
    Graphics 2D - Shapes: 64.0
    Graphics 2D - Fonts and Text: 584.9
    Graphics 2D - GUI: 268.3
    Graphics 3D - Simple: 2763.1
    Graphics 3D - Medium: 778.9
    Graphics 3D - Complex: 92.4
    Memory - Allocate Small Block: 3743.6
    Memory - Read Cached: 3326.7
    Memory - Read Uncached: 3324.2
    Memory - Write: 2786.7
    Memory - Large RAM: 1224.2
    Disk - Sequential Read: 63.4
    Disk - Sequential Write: 56.1
    Disk - Random Seek + RW: 2.7
    CD - Read: 18.6
    CPU Mark: 5485.4
    2D Graphics Mark: 843.4
    Memory Mark: 1065.0
    Disk Mark: 441.6
    CD Mark: 2276.2
    3D Graphics Mark: 1163.1
    PassMark Rating: 2223.6
    Number of CPU: 1
    (4 Core(s)/CPU, 1 Logical(s)/Core)
    CPU Type: Intel(R) Core(TM)2 Extreme CPU X9650 @ 3.00GHz
    CPU Speed: 4336.7 MHz
    Cache size: 6144KB
    O/S: Windows Vista (WIN32)
    Total RAM: 3326.3 MB.
    Available RAM: 2313.4 MB.
    Video settings: 1920x1200x32
    Video driver:
    DESCRIPTION: GeForce 8800 Ultra
    MANUFACTURER: NVIDIA GeForce 8800 Ultra
    BIOS:
    DATE: 04/18/07
    Drive Letter: C
    Total Disk Space: 698.6 GBytes
    Cluster Size: 4.0 KBytes
    File system: NTFS
  • Leo Brennan
    • Nov 2007
    • 15
    my system specs, in case there is interest
    Just in case anyone is interested in the "gear" i used to make my system, here it is:
    * Antec 900 case - with 5 case fans total
    * ASUS P5K3 Deluxe WiFi AP Edition (1333MHz FSB, Dual Channel, DDR3 1333, LGA775 Intel P35+ICH9R chipset)
    * Intel Core 2 Extreme QX9650 3.0GHz, 12MB Cache, 1333 FSB
    * Thermaltake Blue Orb II CPU cooling fan
    * 4 x 1GB OCZ DDR3 1333 MHZ RAM
    * 1000 Watt Ultra X3 Power Supply (modular)
    * BFG tech GeForce 880 Ultra (Overclocked) Graphics Card with 768 MB GDDR3 RAM
    * Seagate 750GB Serial ATA Hard Drive (7200 RPM, 16MB cache, SATA-3G)
    * ASUS QuietTrac SATA DVD Writer Drive (DRW-1814BLT) with Lightscribe
    Again, just for those that are interested. Have a great weekend.
    - Leo
    • CiD
      • Nov 2007
      That's a beast...wow...musta cost a fortune
      on a side note....nice case choice...got one myself....badass
      • merlin
        • Mar 2006
        • 23
        Top 10
        You could easily hit that extra 45 points and maybe a little more with a RAID 0 setup on your drives. Check out my drive Performance compared to yours my Passmark file name is BL8742
        Disk Read - 153
        Disk Write - 161
        Disk Random Seek + RW - 6.6
        Disk mark - 1163
        Nice setup too
        Merlin
        Asus P5N32-SLI Plus
        Intel Q6600 2.4 @ 3.0Ghz
        2Gb Crucial Blistex 4-4-4-12
        2x WD Raptor 74GB 10,000 RPM drives
        1x Seagate Barracuda 300GB 7200RPM
        1x ASUS EN8800GT 512 OC 700/1900
        Coolermaster 750W PSU
        Arctic Cooling Freezer 7 Pro Heatsink
        • Leo Brennan
          • Nov 2007
          • 15
          new score - 2324.4
          I finally did it. I should be in the top 10 now!! Not sure how long it will take to actually show up there though (when you click on the top ten button when searching for baslines to install). My BL number is BL8760. I basically replaced my hard drive with a 10000 RPM Western Digital 150GB. I'm using this one for the operating system only, and using the 750GB Seagate drive I originally had to store all other programs and games. I could probably get an even better score if I went and set up a RAID 0 configuration on my drives, as merlin pointed out in this thread (thanks for the advice by the way!). I have never dabbled with RAID before, but I think both drives need to be the same size in order to set up a RAID configuration. I'll investigate that after the holidays though. I'm also seriously considering a second 8800 Ultra graphics card (using SLI of course) to boost my graphics performance even further. Speaking of graphics cards, mine had been set for best quality, and when I told it best performance instead, my 3D scores skyrocketed! Anyway, my results are below. Again, BL8760 for those interested.
          - Leo
          Results generated on: Saturday, December 01, 2007
          Benchmark Results
          CPU - Integer Math: 834.5
          CPU - Floating Point Math: 3193.9
          CPU - Find Prime Numbers: 2329.5
          CPU - SSE/3DNow!: 19320.5
          CPU - Compression: 21618.8
          CPU - Encryption: 122.2
          CPU - Image Rotation: 4066.2
          CPU - String Sorting: 15048.1
          Graphics 2D - Lines: 147.7
          Graphics 2D - Rectangles: 156.8
          Graphics 2D - Shapes: 65.2
          Graphics 2D - Fonts and Text: 587.1
          Graphics 2D - GUI: 277.3
          Graphics 3D - Simple: 3870.6
          Graphics 3D - Medium: 917.5
          Graphics 3D - Complex: 93.6
          Memory - Allocate Small Block: 3791.8
          Memory - Read Cached: 3362.9
          Memory - Read Uncached: 3380.3
          Memory - Write: 2748.9
          Memory - Large RAM: 1433.6
          Disk - Sequential Read: 74.1
          Disk - Sequential Write: 70.8
          Disk - Random Seek + RW: 5.7
          CD - Read: 18.6
          CPU Mark: 5581.5
          2D Graphics Mark: 859.7
          Memory Mark: 1088.1
          Disk Mark: 544.5
          CD Mark: 2275.5
          3D Graphics Mark: 1562.3
          PassMark Rating: 2324.4
          Number of CPU: 1
          CPU Speed: 4418.8 MHz
          Cache size: 6144KB
          Available RAM: 2412.9 MB.
          Video driver:
          BIOS:
          DATE: 04/18/07
          Drive Letter: C
          Total Disk Space: 139.7 GBytes
          File system: NTFS
          • Leo Brennan
            • Nov 2007
            • 15
            It was expensive.....but i think i won't be needing any upgrades for about 3 or 4 years though. hahahahaha
            • Leo Brennan
              • Nov 2007
              • 15
              Disk Read - 153
              Disk Write - 161
              Disk mark - 1163
              Nice setup too
              Merlin
              thanks, I'll definitely look into that after the holidays. Do they need to be 2 of the same type of drive (size, speed, manufacturer, etc.)?
              -Leo
