Score seems low for E6400 - 717.0
  • vicini
    • Dec 2007
    I think 717 bad for this new PC I just built?? Please help identify where I can improve performance. The whole PC seems sluggish half the time. I haven't even started overclocking yet.
    Motherboard is Evga 680i, E6400, 2GB Corsair, Evga 8800GTS, 500GB Maxtor SATA2
    Thanks for any help.
    CPU - Integer Math: 192.8
    CPU - Floating Point Math: 529.2
    CPU - Find Prime Numbers: 372.6
    CPU - SSE/3DNow!: 4568.9
    CPU - Compression: 4957.5
    CPU - Encryption: 30.1
    CPU - Image Rotation: 1008.6
    CPU - String Sorting: 2447.9
    Graphics 2D - Lines: 164.3
    Graphics 2D - Rectangles: 103.1
    Graphics 2D - Shapes: 6.6
    Graphics 2D - Fonts and Text: 280.9
    Graphics 2D - GUI: 252.4
    Graphics 3D - Simple: 2457.9
    Graphics 3D - Medium: 457.5
    Graphics 3D - Complex: 41.4
    Memory - Allocate Small Block: 2045.7
    Memory - Read Cached: 1655.3
    Memory - Read Uncached: 1564.5
    Memory - Write: 1524.4
    Memory - Large RAM: 592.9
    Disk - Sequential Read: 22.0
    Disk - Sequential Write: 57.8
    Disk - Random Seek + RW: 2.4
    CD - Read: 3.3
    CPU Mark: 1230.7
    2D Graphics Mark: 553.4
    Memory Mark: 545.8
    Disk Mark: 297.3
    CD Mark: 399.3
    3D Graphics Mark: 946.3
    PassMark Rating: 717.0
    Number of CPU: 1
    (2 Core(s)/CPU, 1 Logical(s)/Core)
    CPU Type: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
    CPU Speed: 2133.4 MHz
    Cache size: 2048KB
    O/S: Windows XP (WIN32)
    Total RAM: 2046.5 MB.
    Available RAM: 1715.2 MB.
    Video settings: 1920x1200x32
    Video driver:
    DESCRIPTION: NVIDIA GeForce 8800 GTS
    MANUFACTURER: GeForce 8800 GTS
    BIOS: Version 60.80.06.00.12
    DATE: 10/18/06
    Drive Letter: C
    Total Disk Space: 465.8 GBytes
    Cluster Size: 4.0 KBytes
    File system: NTFS
    • 11115
    Hard drive read seems a bit slow. Did you run the test a few times to confirm this result.
    • merlin
      • Mar 2006
      • 23
      Drive speed
      Make sure you have defraged your harddrive. You should be getting a read speed around 50 to 60 for a drive like that.
      Also check out this sticky posted my the Passmark admin, it contains lots of useful tips on boosting performance.
      http://www.passmark.com/forum/showthread.php?t=1071
      Asus P5N32-SLI Plus
      Intel Q6600 2.4 @ 3.0Ghz
      2Gb Crucial Blistex 4-4-4-12
      2x WD Raptor 74GB 10,000 RPM drives
      1x Seagate Barracuda 300GB 7200RPM
      1x ASUS EN8800GT 512 OC 700/1900
      Coolermaster 750W PSU
      Arctic Cooling Freezer 7 Pro Heatsink
      • vicini
        • Dec 2007
        I defragged and ran it 3 more times still getting slow sequetial reads in low 20s. Nothing running in background. No spyware.
        Disk - Sequential Read: 21.8
        Disk - Sequential Write: 60.8
        Disk Mark: 307.3
        PassMark Rating: 61.5
        Do I have a lemon or what?
        Here are drive specs:
        Maxline Pro 500GB
        Model: 7H500F0
        SATAII 3GB/s
        Thanks for all the help.
        • merlin
          • Mar 2006
          • 23
          Drive speed slow
          Very good drive it is an Enterprise class drive from what I been reading.
          A couple of things you can try make sure your motherboard drivers are up to date Nvidia has the latest drivers for yours here http://www.nvidia.com/object/nforce_winxp_9.53.html
          if that does not solve the problem try the following.
          Next thing you can do is to check the settings for the drive. Right click My Computer - Click Manage - then click on Device manager. look for IDE ATA/ATAPI Controllers click on the + sign next to it.
          Since yours is SATA try double clicking on Secondary IDE Channel and click on Advanced Settings, Look for Current Transfer Mode, one of them should say Ultra DMA mode 6 if it does not then under transfer mode make sure it says DMA if Available.
          let me know
          Asus P5N32-SLI Plus
          • vicini
            • Dec 2007
            I reinstalled the MB drivers to make sure. Still slow reads.
            Went to Device Manager:
            Under Disk Drives it shows location of Maxtor 7H500F0 is Primary ATA Channel and driver date is Microsoft 7/1/2001 Version: 5.1.2535.0
            Under IDE ATA/ATAPI controllers I have the below:
            NVIDIA nForce 590/570/550 Serial ATA Controller - Primary Channel tab
            --- Serial ATA Generation 2-3G is Transfer mode
            --- Let BIOS select transfer mode is checked
            --- Enable read and write caching are both checked
            Primary IDE
            ---Device type - Auto detection
            ---Transfer mode - DMA if available
            ---Current Transfer mode -- Ultra DMA Mode 2
            I can't change any of these settings
            Secondary IDE
            --- Current Transfer mode - Not Applicable
            Everythings seems to checkout here. Any other ideas? I'm about to get another hard drive to test so I can help determine if it is motherboard or hard drive.
            Thanks.
            • merlin
              • Mar 2006
              • 23
              Under the NVIDIA nForce 590/570/550 Serial ATA Controller - Primary Channel tab
              Is there a speed test button there? if so press it and see what it says.
              is there a checkbox for Enable Command Queuing? if there is uncheck it and reboot. try the test again.
              You don't have RAID right just one SATA drive? also under the driver tab what is the date and version listed?
              Asus P5N32-SLI Plus
              • vicini
                • Dec 2007
                Speed Test results:
                Theoretical limit: 300.0
                Burst Speed: 170.3
                Sustained speed: 68.0
                Enable command queuing was unchecked. It's set to let BIOS select transfer mode. Enable read/write caching is checked
                No RAID just one SATAII drive.
                Driver Provider: NVIDIA Corporation
                Date: 9/21/2006
                Version: 5.10.2600.691
                thanks
                • merlin
                  • Mar 2006
                  • 23
                  slow drive per
                  I seem to have found the same thing on another one of my computers with a nforce 4 chipset. Read speed is at 24.2 much slower than it should be it is used as a server. I solved a RAID read speed on my gaming system took me some time though.
                  I will work on what is the cause of this issue and post later.
                  Merlin
                  Asus P5N32-SLI Plus
                  • vicini
                    • Dec 2007
                    I decide to try HD tach software and it's sequential read says avg is 59.2 MB/s. Whom to trust?
