Is my P4 2.3GHz machine faster than my P4 3.4GHz Machine?
  • Anonymous
    • 286
    Hello...
    I wonder if someone might help me to understand this.
    My P4 2.3 GHz machine is faster than my P4 3.4 GHz Machine?
    I ran PT 4.0 on both machines at exactly the time.
    The 2.3 GHz machine finshed all the tests faster.
    Check out the results.
    Dell 8200 Dell 8300 Difference
    Computer P4 2.3 GHz P4 3.4GHz
    Math - Addition 501.84 838.24 67%
    Math - Subtraction 502.06 837.85 67%
    Math - Multiplication 394.85 636.9 61%
    Math - Division 38.24 59.17 55%
    Math - Floating Point Addition 424.21 729.67 72%
    Math - Floating Point Subtraction 424 729.26 72%
    Math - Floating Point Multiplication 410.3 707.83 73%
    Math - Floating Point Division 94.98 146.05 54%
    Math - Maximum MegaFLOPS 486.43 250.59 -48%
    Graphics 2D - Lines 73.45 130.33 77%
    Graphics 2D - Rectangles 90.32 195.15 116%
    Graphics 2D - Shapes 20.07 28.16 40%
    Graphics 3D - Simple 268.56 2321.96 765%
    Graphics 3D - Medium 507.22 1568.83 209%
    Graphics 3D - Complex 242.32 767.38 217%
    Memory - Allocate Small Block 656.48 1151.27 75%
    Memory - Read Cached 1175.31 1788.52 52%
    Memory - Read Uncached 1055.97 1637.78 55%
    Memory - Write 845.59 1253.76 48%
    Disk - Sequential Read 11.83 34.07 188%
    Disk - Sequential Write 13.56 8.48 -37%
    Disk - Random Seek + RW 2.69 2.24 -17%
    CD - Read 2.28 3.15 38%
    MMX - Addition 487.61 777.43 59%
    MMX - Subtraction 487.36 776.39 59%
    MMX - Multiplication 475.01 740.53 56%
    MMX - SSE/3DNow! 1029.75 1672.66 62%
    Math Mark 338.5 509.84 51%
    2D Graphics Mark 245.13 471.52 92%
    Memory Mark 364 568.55 56%
    Disk Mark 74.12 118.23 60%
    CD Mark 113.83 157.32 38%
    3D Graphics Mark 339.37 1552.72 358%
    MMX Mark 315.55 504.8 60%
    PassMark Rating 256.11 529.94 107%
    How long the full suite of tests takes to complete it not an indication of the speed of the machine. It is the number of calculations done during the time the tests are running that is important.
    The over all result, as measured by the PassMark rating, showed the P4 3.2Ghz machine was 107% faster than the P4 2.3Ghz machine. (529 vs 256). Given that the 3.2Ghz machine also has a much faster video card this is about what you should expect.
    Note that in V5 of PerformanceTest (available now) the CPU benchmark will be more accurate becuase it takes into account hyperthreading.
    Passmark
