Wont finish Running [Disk - Sequential Read]
  • warzinak
    • Feb 2011
    The second time now ive done this test and at the same part it has stopped scanning...the animation on the scanning bar still moves but its been stuck for like half and hour...what can i do?
    [edit] unplugged a external hdd thinking maybe it is confusing it and no luck for 3rd time
    Asus A8N32-SLI-Deluxe 939
    AMD 64 3700+ 2.20ghz
    ASUS Geforce 7800 GT
    2gb Kingston RAM
    36gb Raptor HDD
    330gb 7200.10 Barracuda
    What O/S are you running?
    How large is the drive?
    What type of drive is it (SSD, SCSI, etc..)
    How much free space is on the drive?
    What version of PerformanceTest are you using?
    Does the disk write test work?
    • warzinak
      • Feb 2011
      i found out my problem..i was a few mb full of doing the test..
      thanks when u mentioned how much space i had i figured i would check!
      got a score of 562....dono if thats any good for my specs
      2gb Kingston RAM
      36gb Raptor HDD
