Low Memory Score with Passmark 7 64 bit
  • lead341
    • Apr 2011
    I am using a I7-2600 k with 8 GB Ram (1333 Mhz) and an Asus P8P67 Mainboard. I was performing the passmark performance test - while the result of the CPU was excellent (9300 points), the memory mark was quite low - 1500 points. Shouldn´t it be the double?
    greetings,
    lead
    Yes memory mark should probably be a bit higher. Did you run it a few times to get a max?
    The big factors that influence the results are, the CPU speed, the amount of available RAM, 64bit, and the speed of the bus, and the RAM.
    • lead341
      • Apr 2011
      thanks for your reply.
      I guess it was a faulty trial version - after I bought the basic performance test and now the score is about 2450 - perfectly ok ( I downloaded comparative examples ).
      greetings,
      lead
        The trial and the full software are the same. More likely something else changed. e.g. there was something else running in the background during the initial run.
