Low Floating Point Math/Integer Math Score
  • Shawn
    • Dec 2016
    • 7
    6700k stock
    GTX1070
    Asus Z170 Pro gaming
    16gb Corsair LPX
    CPU Mark
    #1 - Intel Core i7-6700K @ 4.00GHz 11796
    #2 - AMD FX-8120 Eight-Core 6636
    #3 - Intel Core i3-4160 @ 3.60GHz 5047
    #4 - AMD FX-8370 Eight-Core 9559
    #5 - Intel Core i5-4590 @ 3.30GHz 7729
    #6 - Intel Core i7-2630QM @ 2.00GHz 6241
    This Computer 7863
    Integer Math
    #1 - Intel Core i7-6700K @ 4.00GHz 18631
    #2 - AMD FX-8120 Eight-Core 11185
    #3 - Intel Core i3-4160 @ 3.60GHz 8753
    #4 - AMD FX-8370 Eight-Core 24250
    #5 - Intel Core i5-4590 @ 3.30GHz 9262
    #6 - Intel Core i7-2630QM @ 2.00GHz 10348
    This Computer 13061
    Floating Point Math
    #1 - Intel Core i7-6700K @ 4.00GHz 8202
    #2 - AMD FX-8120 Eight-Core 5439
    #3 - Intel Core i3-4160 @ 3.60GHz 3438
    #4 - AMD FX-8370 Eight-Core 8431
    #5 - Intel Core i5-4590 @ 3.30GHz 8055
    #6 - Intel Core i7-2630QM @ 2.00GHz 4625
    This Computer 2264
    Prime Numbers
    #1 - Intel Core i7-6700K @ 4.00GHz 31.6
    #2 - AMD FX-8120 Eight-Core 25.7
    #3 - Intel Core i3-4160 @ 3.60GHz 13.0
    #4 - AMD FX-8370 Eight-Core 33.3
    #5 - Intel Core i5-4590 @ 3.30GHz 32.3
    #6 - Intel Core i7-2630QM @ 2.00GHz 20.8
    This Computer 30.4
    Extended Instructions (SSE)
    #1 - Intel Core i7-6700K @ 4.00GHz 534
    #2 - AMD FX-8120 Eight-Core 94.1
    #3 - Intel Core i3-4160 @ 3.60GHz 162.3
    #4 - AMD FX-8370 Eight-Core 125.9
    #5 - Intel Core i5-4590 @ 3.30GHz 262.2
    #6 - Intel Core i7-2630QM @ 2.00GHz 120.8
    This Computer 490.2
    Compression
    #1 - Intel Core i7-6700K @ 4.00GHz 16319
    #2 - AMD FX-8120 Eight-Core 8873
    #3 - Intel Core i3-4160 @ 3.60GHz 5758
    #4 - AMD FX-8370 Eight-Core 13527
    #5 - Intel Core i5-4590 @ 3.30GHz 8723
    #6 - Intel Core i7-2630QM @ 2.00GHz 8088
    This Computer 14981
    Encryption
    #1 - Intel Core i7-6700K @ 4.00GHz 2775
    #2 - AMD FX-8120 Eight-Core 1226
    #3 - Intel Core i3-4160 @ 3.60GHz 793
    #4 - AMD FX-8370 Eight-Core 1777
    #5 - Intel Core i5-4590 @ 3.30GHz 1381
    #6 - Intel Core i7-2630QM @ 2.00GHz 1040
    This Computer 2524
    Physics
    #1 - Intel Core i7-6700K @ 4.00GHz 711
    #2 - AMD FX-8120 Eight-Core 476.4
    #3 - Intel Core i3-4160 @ 3.60GHz 288.1
    #4 - AMD FX-8370 Eight-Core 545
    #5 - Intel Core i5-4590 @ 3.30GHz 384.4
    #6 - Intel Core i7-2630QM @ 2.00GHz 426.1
    This Computer 721
    Sorting
    #1 - Intel Core i7-6700K @ 4.00GHz 9757
    #2 - AMD FX-8120 Eight-Core 5290
    #3 - Intel Core i3-4160 @ 3.60GHz 3922
    #4 - AMD FX-8370 Eight-Core 7304
    #5 - Intel Core i5-4590 @ 3.30GHz 5637
    #6 - Intel Core i7-2630QM @ 2.00GHz 4682
    This Computer 8930
    CPU Single Threaded
    #1 - Intel Core i7-6700K @ 4.00GHz 2476
    #2 - AMD FX-8120 Eight-Core 1178
    #3 - Intel Core i3-4160 @ 3.60GHz 2104
    #4 - AMD FX-8370 Eight-Core 1623
    #5 - Intel Core i5-4590 @ 3.30GHz 2198
    #6 - Intel Core i7-2630QM @ 2.00GHz 1453
    This Computer 1793
    Thats with a "very long test" stock settings and my 2nd moniter shows 100% CPU use on all cores.
    What could be the problem? I saw the other thread about low FPU score and tried with more or less the same result.
    After running all the test, can you save a baseline file for the machine and Email it to us.
    This will allow us to check things like what O/S you are running, if you are using 32bit or 64bit, some of the temperatures, clock speed, etc..
      Just for reference, it sounds very similar to this post from a couple of months back.
      http://www.passmark.com/forum/perfor...int-math-score
      6700k stock
      Given that you mention that it was running at stock, can we assume you know something about overclocking and it was overclocked in the past?
      As for that other post linked to above, the best conclusion we could come to was that overclocking might have damaged the CPU. We honestly don't know if that was true, but we couldn't find any other explanation.
      • Shawn
        • Dec 2016
        • 7
        System is a few weeks old, i fiddel with the core speed a bit but never had any stability issues, never over 4.6 or 1.35Vcore.
        System is at stock speed since i need to work out why it is underperforming. Note it was underperforming before any OC.
        At the moment i am dealing with high CPU load in Battlefield 1 80-90% and that causes stuttering in the game, even with low graphic settings (GPU is working anywhere between 10-99% during different settings)
        OC didn´t solve anything.
        I have tried every freeware benchmark tools i could get my hands on with different results, either fairly average score.
        Userbenchmark is spot on CPU but GPU:
        Nvidia GTX 1070
        35,440 User benchmarks - Average bench 130%
        Asus(1043 859
        MaxC: 1911 MHz, MaxM: 2002 MHz, Ram: 8GB, Driver: 376.19
        Performing way below expectations (4th percentile)
        CPU goes like this:
        Intel Core i7-6700K-
        63,843 User benchmarks - Average bench 97%
        LGA1151, 1 CPU, 4 cores, 8 threads
        Base clock 4 GHz, turbo 4.4 GHz (avg)
        Performing way above expectations (93rd percentile
        Passmark gives average GPU but low CPU score....
        I dont get it, it must be software related. me and ½ of BF1 forums are full of people dealing with high CPU load so i tried to see if i could get some fact recorded(benchmark) showing the problem.
        Only in stresstest does my system ever reach over 60c and never 70c
          Can you make a performance per CPU core table like this and post it.
          Also, as mentioned above, sending us a baseline file would be good.
          I am still thinking CPU damage is a possibility.
          • Shawn
            • Dec 2016
            • 7
            Default - 8
            1 core - 1275
            2 core - 2384
            3 core - 2393
            4 core - 2380
            5 core - 2389
            6 core - 2407
            7 core - 2437
            8 core - 2450
            This is AIDA showing CPU usage during long test of Floating point math running 8 cores.
            ------------------------------AIDA64--------------------------
            Field Value
            CPU Properties
            CPU Type QuadCore Intel Core i7-6700K, 4033 MHz (40 x 101)
            CPU Alias Skylake-S
            CPU Stepping R0
            Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2, FMA, AES
            Min / Max CPU Multiplier 8x / 83x
            Engineering Sample No
            L1 Code Cache 32 KB per core
            L2 Cache 256 KB per core (On-Die, ECC, Full-Speed)
            L3 Cache 8 MB (On-Die, ECC, Full-Speed)
            CPU Physical Info
            Package Type 1151 Contact FC-LGA
            Package Size 37.5 mm x 37.5 mm
            Process Technology 14 nm, CMOS, Cu, High-K + Metal Gate
            Typical Power 95 W
            CPU Manufacturer
            Company Name Intel Corporation
            Product Information http://ark.intel.com/search.aspx?q=I...ore%20i7-6700K
            Driver Update http://www.aida64.com/driver-updates
            Multi CPU
            Motherboard ID A M I ALASKA
            CPU #1 Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4008 MHz
            CPU #2 Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4008 MHz
            CPU #3 Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4008 MHz
            CPU #4 Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4008 MHz
            CPU #5 Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4008 MHz
            CPU #6 Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4008 MHz
            CPU #7 Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4008 MHz
            CPU #8 Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4008 MHz
            CPU Utilization
            CPU #1 / Core #1 / HTT Unit #1 100%
            CPU #1 / Core #1 / HTT Unit #2 100%
            CPU #1 / Core #2 / HTT Unit #1 100%
            CPU #1 / Core #2 / HTT Unit #2 100%
            CPU #1 / Core #3 / HTT Unit #1 100%
            CPU #1 / Core #3 / HTT Unit #2 100%
            CPU #1 / Core #4 / HTT Unit #1 100%
            CPU #1 / Core #4 / HTT Unit #2 100%
            Sensory file: during floating point math at 100% load
            Field Value
            Sensor Properties
            Sensor Type Nuvoton NCT6793D/5539D/5563D (ISA A00h)
            GPU Sensor Type Diode (NV-Diode)
            Motherboard Name Asus B150 Pro Gaming / H170 Pro Gaming / Z170 Pro Gaming Series
            Temperatures
            Motherboard 26 °C (79 °F)
            CPU 38 °C (100 °F)
            CPU Package 41 °C (106 °F)
            CPU IA Cores 41 °C (106 °F)
            CPU GT Cores 30 °C (86 °F)
            CPU #1 / Core #1 42 °C (108 °F)
            CPU #1 / Core #2 42 °C (108 °F)
            CPU #1 / Core #3 37 °C (99 °F)
            CPU #1 / Core #4 39 °C (102 °F)
            PCH 38 °C (100 °F)
            VRM 40 °C (104 °F)
            GPU Diode 49 °C (120 °F)
            Temperature #1 29 °C (85 °F)
            Cooling Fans
            CPU 969 RPM
            Fan #21 840 RPM
            Pump #1 1980 RPM
            GPU 0 RPM (0%)
            Voltage Values
            CPU Core 1.248 V
            +3.3 V 3.280 V
            +5 V 5.000 V
            CPU Standby 1.025 V
            VCCIO 0.976 V
            VCCSA 1.072 V
            PCH Core 0.992 V
            DIMM 1.208 V
            Current Values
            CPU 29.00 A
            Power Values
            CPU 36.19 W
            CPU Package 39.00 W
            CPU IA Cores 35.50 W
            CPU Uncore 2.41 W
            DIMM 1.09 W
            I really appreciate your patience and your support.
              Those per core benchmark number so make it seem like the same issues we previously saw.
              For a CPU that is supposedly running under full load for an extended period, temperatures of 37C to 41C seem a bit low. Or maybe you just have good cooling.
              I don't suppose you know anyone with a compatible CPU (1151 socket) that you could borrow to test. As this would quickly determine if it was the CPU at fault.
              • Shawn
                • Dec 2016
                • 7
                Those low temps were from the long test, 30 sec or so..
                Heres after 45 min of AIDA64 stress
                Field Value
                Sensor Properties
                Temperatures
                Motherboard 28 °C (82 °F)
                CPU 51 °C (124 °F)
                CPU Package 63 °C (145 °F)
                CPU IA Cores 63 °C (145 °F)
                CPU GT Cores 40 °C (104 °F)
                CPU #1 / Core #1 66 °C (151 °F)
                CPU #1 / Core #2 66 °C (151 °F)
                CPU #1 / Core #3 61 °C (142 °F)
                CPU #1 / Core #4 57 °C (135 °F)
                PCH 45 °C (113 °F)
                VRM 56 °C (133 °F)
                GPU Diode 60 °C (140 °F)
                Temperature #1 37 °C (98 °F)
                Cooling Fans
                CPU 960 RPM
                Fan #21 900 RPM
                Pump #1 1950 RPM
                GPU 1472 RPM (40%)
                Voltage Values
                CPU Core 1.280 V
                +3.3 V 3.264 V
                +5 V 5.000 V
                CPU Standby 1.025 V
                VCCIO 0.976 V
                VCCSA 1.072 V
                PCH Core 0.992 V
                DIMM 1.200 V
                Current Values
                CPU 58.00 A
                Power Values
                CPU 74.24 W
                CPU Package 64.65 W
                CPU IA Cores 60.53 W
                CPU Uncore 1.24 W
                DIMM 2.88 W
                Unfortunately I dont have any 1151 cpu´s
                Do you know any other program that test FPM like Passmark ?
                • Phlagg
                  • Dec 2016
                  Shawn,
                  Did you do a clean install of Windows for this build, or use an existing drive image? I was experiencing the same issue as you (low Floating Point, Integer, Single Threaded CPU scores), and I tried replacing the CPU (specifically asked for one from a different batch) and motherboard with no luck. It wasn't until I did a clean install of Windows 10 that the issue was fixed. I had upgraded from an AMD CPU, so I am thinking there may have been a chipset driver issue, but I'm not an expert so can't say for certain.
                  Hopefully that's your problem too and you can get it sorted.
                  Cheers!
                  • Shawn
                    • Dec 2016
                    • 7
                    Originally posted by Phlagg
                    Shawn,
                    Cheers!
                    Hi Phlagg
                    I will format C again after i get a new M.2 ssd Hopefully this will help.
                    As a mentioned earlier, some players of BF1 are having trouble with CPU usage and I´m getting them to test their CPU on passmark and see what score they get and see if theres any relations there.
                    • Shawn
                      • Dec 2016
                      • 7
                      Hi David
                      i did a clean install and installed Win10Pro on another drive.
                      first thing i did after install drivers was to run your bench.
                      It fixed everything now. its sits right in the middel. I have NO idea what changed. And i am very irritated about that since i would like to know what it was.
                      I am downloading BF1 again too see if it has improved ingame there.
                      Here are the results:
                      CPU Mark
                      This Computer 11474
                      Integer Math
                      This Computer 19377
                      Floating Point Math
                      This Computer 7803
                      Prime Numbers
                      This Computer 32.2
                      This Computer 546
                      Compression
                      This Computer 15443
                      Encryption
                      This Computer 2618
                      Physics
                      This Computer 705
                      Sorting
                      This Computer 9218
                      CPU Single Threaded
                      This Computer 2348
                        Interesting. Glad it is fixed. Thanks for following it up.
                        It is a shame we don't know the root cause. Maybe it was some 3rd party software that isn't now installed after the clean Windows install. Or maybe changes in the device drivers that are in use. Or power control settings.
                        • Shawn
                          • Dec 2016
                          • 7
                          BF1 runs exactly like it should. around 100 fps at 1444p with 144hz moniter in ultra.
                          I will install all my software, afterburner,aida and such and test after each install, if everything is ok then i will try OC cpu, then ram and finally GPU.
                          • dkaplanpa
                            • Apr 2018
                            Had this same problem. Integer scores of 15,000 and FP scores also far below what they should be for 8700K overclocked to 4700+ on an ASUS Maximus X Code. Did a clean Windows install and integer score was up to 28,643, with a cpu score of 16,474 vs about 9900 before. Started installing back software - Corsair link, AIDA64 Extreme, the newest Nvidia graphics driver, and scores stayed the same. Whew ...
                            Haven't reinstalled ASUS AI Suite 3.0 yet. Might try it later. But, if that messes the scores up, then I'd have to reinstall again. So ... thinking of closing the boot drive as it is now before trying with ASUS. Or ... maybe just leave well enough alone.
                            Thanks much for pointing out the fix!!
                              A couple of weeks ago ASUS confirmed a bug in their AI Suite software. It was making machines slower instead of faster.
