Help Please ???
  • Mike25
    • Apr 2006
    • 7
    Help Please ???
    most of my scores are ok but there is a few that are bugging.
    if any one has some tip they would be most helpfull.
    i have uploaded my results but i am new to fourms and couldnt get the pic format to post so here is the results
    i have marked the two by (this is one)
    i would have guessed that these scores would be higher.
  • Mike25
    • Apr 2006
    • 7
    sorry new to fourms
    Test Name PerfRes.bmp This Computer
    CPU - Integer Math 64.38 -
    CPU - Floating Point Math 302.01 -
    CPU - Find Prime Numbers 178.80 -
    CPU - SSE/3DNow! 1299.59 -
    CPU - Compression 1953.67 -
    CPU - Encryption 18.54 -
    CPU - Image Rotation 203.41 -
    CPU - String Sorting 576.76 -
    Graphics 2D - Lines 49.65 -
    Graphics 2D - Rectangles 1.78 - ( this is one )
    Graphics 2D - Shapes 13.44 -
    Graphics 2D - Fonts and Text 76.64 -
    Graphics 2D - GUI 95.28 -
    Graphics 3D - Simple 343.59 -
    Graphics 3D - Medium 40.92 -
    Graphics 3D - Complex 4.77 - ( this is one )
    Memory - Allocate Small Block 1065.63 -
    Memory - Read Cached 1777.42 -
    Memory - Read Uncached 1353.23 -
    Memory - Write 663.87 -
    Memory - Large RAM 162.90 -
    Disk - Sequential Read 381.07 -
    Disk - Sequential Write 35.73 -
    Disk - Random Seek + RW 4.23 -
    CD - Read 7.97 -
    CPU Mark 392.94 -
    2D Graphics Mark 148.89 -
    Memory Mark 371.36 -
    Disk Mark 1522.67 -
    CD Mark 976.36 -
    3D Graphics Mark 124.58 -
    PassMark Rating 601.14 -
    System information - This Computer
    CPU Manufacturer:GenuineIntel
    Number of CPU: 1
    CPU Type: Intel(R) Celeron(R) CPU 2.53GHz
    CPU Speed: 3129.7 MHz
    Cache size: 256KB
    O/S: Windows XP (WIN32)
    Total RAM:1056423936 Bytes
    Available RAM:731979776 Bytes
    Video settings: 1280x1024x32
    Video driver
    DESCRIPTION:
    VisionTek RADEON 9200 Series
    MANUFACTURER:
    BIOS:
    BK-ATI VER008.017D.031.000
    DATE:
    06/01/11
    Drive Letter: C
    Total Disk Space: 9.8 GBytes
    Cluster Size: 4 KBytes
    File system:NTFS
    PassMark(TM) PerformanceTest 6.0 (http://www.passmark.com)
    Results generated on: Sunday, April 23, 2006
      Yes, all the 2D results are a little on the low side. The 3D results aren't so bad.
      Have you checked you have the latest device drivers for your video card? I might also be tempted to have a look in the BIOS just to check that you don't have the AGP speed turned down (or something like this). If you have your desktop skinned (or themed), then try turning that off.
      • Mike25
        • Apr 2006
        • 7
        my video card is a pci card but i did turn up the AGP speed (I didnt think it would help) and i up dated the drivers.
        I am running windows blinds so i turned it off.
        but still no luck i got the same scores
        Any other ideas
          I would be tempted to uninstall blinds completely (temporarily). Maybe it has installed some device drivers that are still active.
          It is very hard to guess at the cause of minor performance problems without having the machine to play with.
          Could to some other background tasks like remote desktop tools, spyware, other BIOS settings.
          Other rarer things we have seen a bad performance when running 2 or more monitors, bad performance running at strange non standard resolutions & badly configured SLI dual video cards.
          There are also a few video card device driver settings that can effect the results. In particular the colour depth and hardware acceleration being on or off.
          • Mike25
            • Apr 2006
            • 7
            thanks
            I ended up taking the card back and got a AGP card.(Radeon 9550)
            I ran the test and got much better results
            Thank You for all your help
            Mike
