Extremely low DirectX 9 (Complex) test score - any ideas why?
    Horrigan, What hardware do you have?
    Did you try the suggestion above?
    • Mikehame
      • Jun 2013
      Well this is gorgeous. My directx9 results are showing too low.
      I have Gigabyte HD 6850 OC graphic card, and I compared it to several others.
      Why is this happening?
        Mikehame, What hardware do you have?
        Were you CPU results OK?
        Is your video card in the correct PCi-E slot.
        Did you also try the suggestion above?
        • Mikehame
          • Jun 2013
          Thanx David for answer.
          I solved the problem. I had an old graphic driver from original CD (2010)
          So I update it to newest from AMD website, and everything works fine, even better.
          Here is my new baseline ID: 100851
          and link:
          http://www.passmark.com/baselines/V8...id=10085147668
          And here is the image of improvement, old and new results:
            There must have been something broken in those old drivers for the difference to be so large. Good that you were able to identify and fix the problem however.
