GPU low usage
  • RubenCarner
    • Apr 2019
    GPU low usage
    I want to know how to make sure the passmark performance test gpu benchmark test will use 99% of a gpu usage.
    Thats not what i've been seeing on performance test... my gpu usage is random, and typically 85% on dx11 test, 60% on dx9 test, 99% on dx 10 test, and so on...
    gtx 1060 6gb
    It depends on the CPU speed.
    Faster CPUs can place more load on the video card.
    You can also use the Advanced Tests to select a higher resolution (if your monitor supports it) and that will also place more load on the video card.
