PT9 Crashes at startup on Baytrail system - Intel Celeron CPU N2930
  • IdealLife
    • Sep 2019
    Hi there,
    Having a problem with BSoD when starting PT9. Anyone have a couple pointers?
    0.000s - DEBUG: Starting...
    0.063s - DEBUG: Start time: 2019/09/27, 09:51:46.521
    0.094s - DEBUG: PerformanceTest 9.0 build 1031 64-Bit
    0.110s - DEBUG OS: Windows 10 build 14393 (64-bit)
    0.125s - DEBUG Path: C:\Program Files\PerformanceTest
    0.156s - DEBUG Command line: PerformanceTest64.exe debugmode
    0.172s - Date: 09/27/19 09:51:46
    0.203s - HORZRES - 1024 VERTRES - 768
    0.219s - LOGPIXELSY - 96 LOGPIXELSX - 96 DPIScale - 1.000000
    0.219s - DEBUG: Opening splash window
    0.844s - DEBUG: UTF8StringToWChar string truncated (FCBGA1224/FCPGA932nm -> FCBGA1224/FCPGA)
    0.985s - DEBUG: Init CD Burner
    1.188s - DEBUG: Retrieving Computer Name
    1.203s - DEBUG: Retrieving OS Name
    1.297s - Windows 10 build 14393 (64-bit)
    1.313s - DEBUG: Retrieving Graphics Info
    2.016s - Video adapters: iNumDD 2
    2.031s - Video adapter 0: bDisplay: 1 szDeviceDescription: Intel(R) HD Graphics szDriverVersion: 10.18.10.5059 : Memory: 2155507712
    2.047s - Monitor 0:1 1024x768x32 60Hz 96 DPI (Primary monitor)
    2.047s - Video adapter 1: bDisplay: 0 szDeviceDescription: szDriverVersion: : Memory: 0
    2.063s - DEBUG: Retrieving USB Info
    2.953s - DEBUG: GetProcessList
    2.953s - DEBUG: SysInfoDLL_Results::GetProcessList start
    2.969s - DEBUG: SysInfoDLL_Results::GetProcessList finished
    2.985s - DEBUG: Checking language and local
    3.000s - DEBUG: Got language and local
    3.016s - DEBUG: Creating main window
    3.156s - DEBUG: Updating Baseline List
    3.172s - Updating baseline: using OS:
    3.188s - Windows 10 build 14393 (64-bit)
    3.344s - DEBUG: Finished updating Baseline List
    3.516s - CD3DApplication::BuildDeviceList start
    3.516s - CD3DApplication::BuildDeviceList adapter 0 of 1
    3.547s - CD3DApplication::BuildDeviceList finish
    3.563s - DEBUG PERF: Initialize3DEnvironment
    3.563s - DEBUG PERF: AdjustWindowForChange start
    3.578s - DEBUG PERF: AdjustWindowForChange done
    3.594s - DEBUG PERF: DX9 CreateDevice
    3.610s - DEBUG PERF: DX9 CreateDevice OK
    3.625s - DEBUG PERF: DX9 CreateDevice success
    Thanks!
    See this FAQ post to start with
    https://www.passmark.com/support/per...p#launch_crash
    • IdealLife
      • Sep 2019
      David,
      Well, thanks, was able to narrow down a bit. The command line /DontGather options caught my eye, as the crash was happening after displaying the 'Collecting CPU information' message.
      Didn't see it listed, but tried a /DontGatherCPU option, and no crash this time.
      There is a popup message that 'Multimedia instruction tests cannot be run as the CPU doesn't support SIMD.'
      Any suggestion how to narrow down further?
      Thanks!
        I've sent you an Email. We'll probably need to send you a debug build next week.
