Hi
Hardware NP DV9500 running fresh install Windows 7 with latest updates
DXDIAG reports
Core Duo CPU T7300 @ " GHz
NVIDIA GeForce 8400M GS Driver version 9.18.12.4144 (23/02/2015)
Display 1440x900 Generic PnP Monitor
Directx11 running
Full test run. Gets to Running Graphics 3D - DirectX10 and then freezes when the end of the green line is under the - (3D - DirectX) in the title. Prior to this it reported unable to use desired resolution of 1650x1080 (Not surprising as max is 1440x900!)
tests->3d Graphcs->Directx11 reports 'Failed to create 3D environment. Most likely card does not support DirectX11 (Why did windows install Directx11?)
Tests-3D Graphics->Directx10 reports unable to use desired resolution of 1650x1080 (Not surprising as max is 1440x900!) runs for c.20 secs and then crashes
Advanced->3D Graphics
Directx11 - as above
Directx10 Resolution 1440x900 crashes
Directx9 complex Works fine
So what is this trying to tell me?
How do I run a full set of benchmark tests?
I should use Directx9 or what
TFAI
DXDIAG reports
Directx11 running
TFAI
