Put Together Intels New Core 2 Duo need help tweaking!
  • keith1961
    • Aug 2006
    I'm building one of these new Intels. I've got what I believe is a fairly good score but I sure could use some tweaking. First, how do I improve the Hard drive and DVD. I could really raise my score if I could make my drives work a lot better. Here's my Data:
    Intel D975XBX Motherboard
    Intel Core 2 Duo Processor E6700 2.66Ghz, 4Mb L2 Cache, 1066Mhz FSB
    Kingston Hyper X PC28000 1066Mhz DDR2, 2Gb
    Seagate ST32508223AS 250Gb SATA 3.0Gbs Hard Drive
    LG GSA-H10 16X DVD Dual Double Layer RW
    XFX GeForce 7900 GTX 512Mb PCI Express 665Mhz DDR# Graphics Controller
    CPU – Integer Math 227.0
    CPU – Floating Point Math 621.2
    CPU – Find Prime Numbers 664.7
    CPU – SSE/3DNow! 5399.5
    CPU – Compression 5907.5
    CPU – Encryption 34.9
    CPU – Image Rotation 1146.4
    CPU – String Sorting 3662.0
    Graphics 2D – Lines 184.5
    Graphics 2D – Rectangles 484.1
    Graphics 2D – Shapes 42.6
    Graphics 2D – Fonts & Text 326.7
    Graphics 2D – GUI 266.1
    Graphics 3D – Simple 1898.7
    Graphics 3D – Medium 493.0
    Graphics 3D – Complex 49.8
    Memory – Allocate Small Block 2603.2
    Memory – Read Cached 1950.8
    Memory – Read Uncached 1895.9
    Memory – Write 1543.4
    Memory – Large RAM 850.9
    Disk – Sequential Read 59.7
    Disk – Sequential Write 56.2
    Disk – Random Seek + RW 2.7
    CD – Read 0.34
    CPU Mark 1517.3
    2D Graphics Mark 1053.9
    Memory Mark 653.9
    Disk Mark 429.1
    CD Mark 41.1
    3D Graphics Mark 781.4
    PassMark Rating 858.2
    I have been in the Low Voltage Field for 25 years. Now I am specializing in the Video Surveillance field. I assemble all my DVR's using only PC based systems. I will be happy to answer any questions when I have time. Good Day!
    HD results look OK. Close to 60MB/sec read & write. Which is not too bad.
    For the CD test, use a CD (or DVD) with a small number of really large files on it for testing. Lots of small files means more seeking and a lower read speed.
    • cordless
      • Sep 2006
      In reference to your test results I also have Dual Core but its AMD and my results ?
      I jut got a Dual Core AMD 4200+ and my scores suck.. Do I need to mess with the BIOS settings.
      PassMark Rating 558.28
      Benchmark Results
      CPU - Integer Math 139.17
      CPU - Floating Point Math 787.32
      CPU - Find Prime Numbers 239.04
      CPU - SSE/3DNow! 3084.23
      CPU - Compression 3913.05
      CPU - Encryption 27.58
      CPU - Image Rotation 634.46
      CPU - String Sorting 2290.94
      Graphics 2D - Lines 147.95
      Graphics 2D - Rectangles 245.87
      Graphics 2D - Shapes 39.06
      Graphics 2D - Fonts and Text 218.46
      Graphics 2D - GUI 228.62
      Graphics 3D - Simple 567.83
      Graphics 3D - Medium132.48
      Graphics 3D - Complex 35.50
      Memory - Allocate Small Block 1734.30
      Memory - Read Cached 1080.56
      Memory - Read Uncached 953.36
      Memory - Write 1055.83
      Memory - Large RAM 864.53
      Disk - Sequential Read 26.49
      Disk - Sequential Write 11.94
      Disk - Random Seek + RW 2.65
      CD - Read 7.56
      CPU Mark 913.982
      D Graphics Mark 675.39
      Memory Mark 420.56
      Disk Mark 148.59
      CD Mark 925.263
      D Graphics Mark 235.48
      System information - This Computer
      CPU Manufacturer:AuthenticAMD
      Number of CPU: 1 (2 Core(s)/CPU, 1 Logical(s)/Core)
      CPU Type: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
      CPU Speed: 2211.2 MHz
      Cache size: 512KB
      O/S: Windows XP
      Total RAM:3489058816 Bytes
      Available RAM:3029979136 Bytes
      Video settings: 800x600x16
      Video driver
      DESCRIPTION:
      NVIDIA GeForce 7600 GS
      MANUFACTURER:
      GeForce 7600 GS
      BIOS:Award 6.00
      Version 5.73.22.25.00
      DATE:
      06/19/06
      Drive Letter: C
      Total Disk Space: 38.3 GBytes
      Cluster Size: 4 KBytes
      File system:NTFS
      [/code]
        Cordless, all the results look OK. Except for the hard disk result, which is low.
        If you are planning on spending any time or money on optimization or upgrades this is where I would focus my attention.
        • keith1961
          • Aug 2006
          Work in progress
          I changed my hard drive now. Above I was using a standard SATA drive. Now I put a new WD 10K SATA drive in. Its getting better!
          CPU mark 1540.4
          2D Graphics mark 952.0
          Memory mark 695.1
          Disk mark 562.4
          CD mark 1139.9
          3D Graphics mark 885.6
          PassMark rating 995.6
          My next step is to get rid of the Intel D975X motherboard. To my chagrin I found Intel does not support NVidia SLi. I have 2 7900GTX.
          What would you recommend as the best motherboard for Sli and tweakability?
          I have an obsession to get the best rating. The only problem is I cannot afford those 15K SAS drives. So I am going to use the WD 10K SATA drives. Next I will set them up in RAID.
          I too notice posted on your board 2D rectagles causing a problem. My new NVidia drivers has done the same to me. Any fix/
          Keith
