Ubuntu - Permission not granted - PerformanceTest
  • alexis
    • Nov 2023
    I'm trying to use PerformanceTest on Ubuntu.
    But when I follow the process " ./pt_linux_x64", Ubuntu replies "bash: Permission not granted".*
    Whether I'm root or not with sudo​.
    How to do ?
    Alexis
    You need to enable execution permission for the file. This is a standard Linux / Unix requirement for executables.
    Depending on what version you have, run,
    For the 64bit x86 version of PerformanceTest.
    sudo chmod +x ./pt_linux_x64
    If using the 32bit version
    sudo chmod +x ./pt_linux_arm32
    If using the ARM CPU version
    sudo chmod +x ./pt_linux_arm64
    Note: sudo is not required if you are already the owner of the file in the file system.
    This is also covered on the FAQ page.
